Although I have never used them, the benefit is allow more adjustment for alignment. Older frames have a tendency to twist over many miles not giving you enough latitude to get the alignment within specs. The offset shaft moves the pivot center on the upper A frame without having to resort to pulling the frame to get it back to the original factory specs.
67 Firebird Convertible |
Used these effectively on my 1968 Firebird.
- Tom |
Did you notice a difference? Did it come with improved alignment specs?
It's been a while since I did this. I had been told that my frame had sagged and that made it difficult to shim for alignment properly. I got my specs from http://www.pozziracing.com/first_gen...gnment%20specs
I think I'm running -1.3 Camber, +4 Caster and 1/8 toe in
- Tom |
See if you can get the alignment you want with stock shafts. If not, then get the offsets
- Tom |
They are called "Problem Solvers". Here's the quote right off the link you provided.
Front Control Arm Shaft - Chevrolet Camaro Fits Left or Right Side. Offset Shaft Kit Provides Additional Camber Adjustment of up to 1-1/2 degrees
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Yeah, I used them on two of my cars, and they are great.
Build it fast, build it right, hold On TIGHT !!! |
