Looking to run sealing rings dry deck.
No head gaskets. 6.535 rod, yes a short rod 1.53 rod/stroke ratio 1.4 compression height 10.240" deck height 0.180" down the hole, no valve pockets, would be 8.67compression with a 4.25 x 4.25 engine. Turbocharged 20+ psi boost, approx. 5500 rpm Solid roller 250 duration at 0.050", 0.585 total lift, 115 c/l Street/Strip Dragweek combo |
NitrousTTF???
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
v869tr6,
Bob and Frank now have Marty's Sealing Rings. That might be an alternative. They are a solid square cut ring. Then there are also pressurized gas rings available. http://www.agemak.com/tr_/pdf/Helico...tal_O-Ring.pdf We used (at work) a lot of the Helicoflex pressurized gas rings in a lot of our single cylinder engine test engines. Very good durability overall. They will make most bore diameters in a variety of sealing ring tube diameters. We used the .090"+ tube diameter parts as they have a lot of cylinder head lift sealing capability. Tom V.
![]() Quote:
BBC run way worse rod/stroke ratios Trying to build a tuff engine. |
I'd try to find another way to dish volume than running the piston .180 down. Seems to me incomplete combustion would result.
No reason why the short rod combo won't work, they will put more side load into the bore walls for sure,but shouldn't be a problem with an aftermarket block.
We run the piston .120 to .170 down with a 6.700 rod. This is to achieve a nominal 6.0 CR for nitro. Flat piston. We do run O-rings with a copper gasket which gives us an additional way to raise/lower compression through gasket thickness. No reason the rings wouldn't work. If you haven't done it already, you might want to consider up-sizing the deck fasteners to 9/16". If the heads you are using will allow, that will give you 30-40% more clamping load at the deck.
When I got my sealing rings from Marty. He told me to torque it down to 100 ft lbs with moly. He said the Eheads would collapse on anything over 100. I am running a similar combo like yours if I ever finish my project.
Scott Tiemann actually had a E-head head issue very early on (with removing a lot of boss material on the head bolt support bosses) of the second gen E-heads. This may have been where Marty first saw the Torque issue. Believe several fixes were tried with limited success. Eventually I think the fix was less porting for a few CFM and more boost and actually higher durability of the heads.
Tom V.
Curious, with a short rod like that, is there any concern with how far the piston is out of the bore on BDC? I ask this question not so much for a race engine, but more a street engine since Ed plans on doing DW with a lot of street miles.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process Last edited by Hooter; 02-07-2017 at 03:24 PM. |
Would be nice to have the piston length and then we could do the match vs the compression height/stroke, etc. It has been posted before what the actual Pontiac Bore length is on a stock block but I do not have a dimension on a IA-2 block.
Tom V.
![]() Quote:
If I add the 1/8" less stroke ( 4.5 - 4.25 divided by 2 ) to the 6.535 rod I get 6.66" so the pin would be 0.040" farther down the bore. Wonder what the 4.5"+ cranks use for a rod length? |
![]() Quote:
So with 1/2 of the stroke 2.125 added to 3.99" (10.24-6.25 ) I get 6.115" at BDC to the bottom of the liner. 6.535 rod minus 6.115 = 0.420" using a 0.990" pin 0.075" of the pin would be out of the bore at bottom dead center. Is the math right? |
![]() Quote:
My E-heads are crushing on the 3 exhaust studs mainly the center one, top hat washers didn't fix the problem, now to press in some chrome moly tubes so I can get down to just the deck part of the head.
![]() Quote:
6.250" - 1.400" - 4.250" - (0.990"/2) = 0.105" out of the bore. Tom V.
I did that to my Eheads. I spoke to Charlie and I had my machinist press the .120 moly tubes on the 3 exhaust locations. I have the step washers on all the rest. Need this project to get done
Did the tubes break into the exhaust ports? Are the ports ported?
Yup, I have the Butler wideports. The machinists knurled the tubes before pressing it in. He said no way it will leak and he milled the tubes a little higher than the surface. This way it can sink a little and not crush the head. I cant wait to get done, waiting for my headers. I finally got a TIG and will fabricate the rest when I get my turbo headers.
