Old 02-25-2017, 10:22 AM
crustysarge crustysarge is offline
Default 70 Lemans Sport Interior Panel Fit
My first A-body, it has turned into a 5 year project with no end in sight. I am trying to pre-fit new interior panels and have attached pix. Please take a look and see if I am on target. The panels are Legendary. I had to bend the inner lip some to get the panel over the body and the headliner press on trim at the curve in the back really raises the panel. How about the sausage on the door trim, is it correct to bend under the panel and the little plastic flap be out? It is pretty stout and bent that way since it is the original. The window crank is not centered but that is as good as it gets, panel is not going down any more that what it is now. Comments?
ID:	448162   Click image for larger version
ID:	448163   Click image for larger version
ID:	448164   Click image for larger version
Old 02-25-2017, 01:08 PM
JSPONT's Avatar
JSPONT JSPONT is offline
I will look at my stock 70 lemans later, Ill let ya know.
