Two '64 Tripower Carb Sets "Before" Restoration.
Here are two sets of carbs I'm restoring this week. Thought you may be interested to see how these 50+ year-old carbs can be brought back to life.
The first set has both the center carb throttle lever and the rear carb throttle lever loose. I'm usually able to re-swage the shaft to tighten these without drilling/tapping and putting a screw in. The rear carb fuel inlet threads are stretched and will require a thread insert. The second set front carb needs a replacement airhorn. That carb also has a broken brass vacuum fitting in the base, which can be fixed by drilling/tapping and putting a close nipple in place of the broken one. The center and rear carb on that setup have twisted off/broken off air cleaner studs in the airhorn webs which will need to be drilled out and re-tapped. I'll post the "after" pictures when the setups are ready to ship.
Here's one of the setups after restoration. The carbs were the rough-looking ones in the previous post. They are sitting on a spare '64 intake I use for tweaking fuel lines and presetting linkage before shipping the carbs back to the owners.
This setup has the 9777061 linkage introduced in '64 as you can see from the pictures. There was a big Pontiac version and a GTO version. As you can see, this is the GTO version with the provision for the yellow throttle return spring.
You do beautiful work Dick! Very detail oriented.
Here's the second set finished. These are for a '65 GTO. It's a pleasure restoring carbs like these that were not corroded or damaged in their 50+ years of life!
They're sitting on a '64 manifold I use for fitting fuel lines & adjusting linkage.
Nice to see that quality work still exists. Nice job! |
We have a great group of people on this board that are willing and able to help with any issue you may have with restoring or maintaining your old Pontiac. I only wish we had an option like this with our computers, appliances, building maintenance, etc. where we could get knowledgeable help on issues.
Very Nice ...thanks for the pictures :-)
1963 Bonneville SW 421HO 1967 Bonneville SW 400 1969 GP 428 4spd 1970 GTO 400 4spd 1970 Bonneville SW 455 1971 GP 400 4spd 1971 Grandville Conv 455 1972 Catalina Conv 455 1972 Grandville Conv 455 |
Dick, how long does it take for you to get them from picture #1 to #2 ?
2-3 weeks after I get the carbs in my shop. I usually do the zinc dichromate with at least 9 carbs at once.
Thread Tools | |
Display Modes | |
