Old 03-25-2017, 10:07 AM
tinindian68's Avatar
tinindian68 tinindian68 is offline
Default 1968 OHC engine parts for sale
All parts removed from a running 68 250
I'm pulling this engine apart completely, so if you need something not listed, just ask. This is a complete, original engine. Everything is in good usable shape. All prices do not include shipping. Pickup or possible delivery available on the bigger/heavier stuff. Located in Northeastern Pennsylvania.
Everything's negotiable. I'd rather see these parts used than sit around.
Can cover with cam, followers and lifters. $125 ran quiet
68 1bbl head - recent valve job, cleaned and cut. No cracks, you can bolt this on and go. $150
Accessory drive - $50
Fuel pump - $20
Distributor with pertronix conversion. New cap and wires - $100
Power steering set up - comes with all brackets, 69 short water pump and pulley. Water pump was tapped for bypass fitting. Pump ran quiet. Brackets are all in nice shape. Bolt on and go - $300
OHC bell housing with inspection cover - $175
OHC flywheel - $175
A-body motor mounts and frame mounts - $50
1 bbl Air cleaner - $50
1 bbl Carb - $35
Exhaust - nice shape - $100
Starter - $50
Timing cover set - no cracks -$50
Misc brackets, clips, etc - let me know what you need.
Oil fill tube, cap and breather hose - $20
Old 03-31-2017, 04:17 PM
Grokk's Avatar
Grokk Grokk is offline
you still have the Distributor?
Old 03-31-2017, 04:20 PM
Yep.
Shipping would be $13.60 in the US.
Old 03-31-2017, 06:59 PM
Starter, timing cover set and distributor all sold.
Old 04-11-2017, 09:42 PM
pontiacs-r-us's Avatar
pontiacs-r-us pontiacs-r-us is offline
Carb still available?
Old 04-11-2017, 10:17 PM
Yes it is.
Old 04-14-2017, 07:14 PM
Head, Cam Cover, Cam, Lifters and Followers all sold. Thanks Wayne!
Old 04-21-2017, 08:01 AM
Oil fill tube sold!
Old 05-06-2017, 03:55 PM
Here are some pictures of what's left. Feel free to make an offer on this stuff before it goes to eBay.
Bell Housing and Inspection Cover. Includes Clutch Fork. ($175)
Accessory Drive ($50) and Fuel Pump ($20)
Motor Mounts with Frame Mounts ($50)
Thermostat Housing with Bypass ($25)
Carb ($35)
Air Cleaner ($50)
Heat Riser Hose Mount ($25)
Choke ($25)
Carb Bellcrank ($15)
1 BBL Throttle Bracket ($20)
Molded Radiator Hoses - Good Shape ($25)
Head Bolts ($15)
OHC Specific Battery Tray - A Little Thin, but really usable ($20)
68 Single Groove Water Pump Pulley ($30)
Original Coil - Worked Great ($25)
Fuel Line and Vacuum Lines - Someone cut the last 3 inches of fuel off ($20)
Intake/Exhaust Bolt Set ($15)
Misc. Brackets ($5 each)
Manual Steering Box, Rag Joint and Pitman Arm ($100)
Timing Gear ($30)
Old 05-06-2017, 08:41 PM
Also have a complete power steering set up. Includes brackets, pump, alternator and water pump pulleys, belts and a pressure hose that fits the later model o-ring steering box and original flare fitting in the power steering pump $(300). The water pump pulley is a 1969 short pulley. I can include a rebuilt 1969 water pump if needed.
Old 05-15-2017, 08:54 AM
Air Cleaner Assembly sold!
Old 05-15-2017, 07:53 PM
Accessory Drive and Fuel Pump sold!
Old 05-16-2017, 04:12 PM
Motor mounts sold!
Old 05-17-2017, 01:38 PM
Power Steering Set Up sold!
Throttle Bracket sold!
Intake/Exhaust Bolts sold!
Old 05-18-2017, 11:07 PM
Carb sold!
Old 05-20-2017, 08:30 PM
Flywheel sold!
Battery Tray sold!
Old 05-25-2017, 07:37 AM
Bellhousing sold!
Old 05-25-2017, 08:21 AM
The Boss's Avatar
The Boss The Boss is offline
Why are you taking that car apart?
And go racin' in the street.
Old 05-25-2017, 08:42 AM
I rebuilt the head, and ran around with it for a while. It was just completely gutless. I put a Pontiac V8 in its place. Kept the 3 speed. Trying to get it ready for the Pypes show.
Old 05-25-2017, 09:18 AM
The Boss's Avatar
Okay, I was worried you were taking the whole thing apart - not that you can't but having survived as long as it has...
It'll be good to see it again!
