1971 455HO YE block with no VIN?
Back around 1983 - 1984, I picked up a 1971 YE 455HO engine. I recently had someone asking about the block and they wanted to know the VIN number of the block.
I went down today to load up for Autofair. I scraped and wiped the front surface of the block with lacquer thinner, but I can't find a VIN anywhere. I have seen blocks where the VIN was very poorly stamped, but I'm not sure I've seen one with the VIN number completely missing. There is no SR number, the block code is YE, and there is a unit number stamped below the block. It's a 4-bolt main, and I don't think anybody was restamping blocks when they were just used cars. Thoughts anybody? Mike |
Fremont stamp in different location, and some don't get stamped. They're worth more with no vins.
Mike/Illinois |
Fremont VIN is up high near where the passenger side head meets the block. I agree with Mike, I would pay more for a factory stamped block with no VIN.
I am pretty sure I looked in that area. I've seen some block VINs stamped in the location you show. I took some pictures, will have to go back and look at them again. The block was greased, then wrapped up pretty well, so I cut most of the plastic off the front looking for the VIN. This will probably be a block I sell.
I am pretty sure this engine came out of a GTO. I junked an automatic 71 GTO in the early 80s, I think this is the engine out of that car, and I also bought a 71 YE from a friend of mine around 1985 or so. Mike |
interesting!
i just learned something new!!
Mine is up high like Eaglesan13.
Last couple of numbers are pretty light.
JLP |
Here are a couple of photos. I don't see a VIN number at all.
There's a guy looking for a YE block in the wanted section. Doesn't get any better than this.
What's that rule by Gibbs?
Mike/Illinois |
Which casting number is it, and what is the date code?
Date code is B12 or B151.
I'm pretty sure it's the later casting. Maybe they hired a new guy on the line. This block is either three days newer or older than the other YE where the VIN number stamp wasn't perpendicular to the surface. About all you can make out for sure on this block is the 21N. I have two YE blocks, one dated B121 and the other is B151. One VIN is poorly stamped, the other is missing the VIN entirely. Mike |
I think they would both be desirable blocks, because they have the factory EUN and block code stamps. If they were used in a car needing a YE block, and the date code(s) lined up, no one would be able to say they were not original to the car, since the VIN is unreadable (or missing). I wish I would have been able to find a WC block for my car with the same VIN situation.
My 71 WC motor has no VIN. Not that common but they do show up.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
I have a 69 Ta the same way
With having no vin is there anyway to tell if the block is original to the car by using the ENU? Is it listed on the build sheet or PHS documents?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" |
When I was a product rep for GM it wasn't uncommon for me to order a brand new engine from an engine plant. The engine was to replace an engine in a vehicle that had a major failure shortly after the new owner took delivery. The engine plant would pull the complete engine off the line and ship it directly to the dealer I designated. Engine would be just like the ones they normally shipped to the final assembly plant. Because it never went to the final assembly plant it never received a VIN stamping. And because it was a fully assembled engine (had plugs, distributor, plug wires, fuel, injection, etc.) it wasn't considered a SR engine like the ones shipped to the parts division warehouses.. So it never got a SR stamp. The failed engine would be returned for analysis of what went wrong. Have to believe I wasn't the only product rep that did this to satisfy the customer.
Another scenario where an engine may not get a VIN stamp can happen at the final assembly plant. After a vehicle is completely assembled it goes on a dyno for Dynamic Vehicle Test (DVT). If the vehicle passes all it's tests then it goes out the door. However if it fails anything it goes to a repair bay. If during DVT the engine experiences a major internal problem/failure the engine will be removed from the vehicle and another new engine installed. The new engine comes from where pallets full of engines are awaiting installation on the assembly line. Because the engine is taken from there and sent directly to the repair bay it never gets stamped with a ViN. I had heard that the repair bay "may" manually "hand" stamp the VIN on the engine before installation. Don't know if all plants did this and if it was 100% of the time. Note: This may explain why some engine VIN stampings have been found with numbers that are not in alignment (straight). Not saying either of these happened to the engine in question, but you never know. Sorry for the long post. Last edited by 1969GiPper; 03-26-2017 at 08:35 PM. |
X2!
