I'm really been thinking hard about purchasing one of these M22z transmissions. I would like a lower first gear. My 2.52 and 3.36 rear is tough on my clutch on the steep hills we have. Been researching autogear and 5speed.com sites. Don't know who I should go with.
Has anyone here installed one in a Firebird? How do you think a M22z with a first gear 2.98 and a 3.36 rear gear would perform. The output drive ratio would be 10.01 for 1st gear which would be a power horse off the line. Would it be too much? Here is how the final output drive ratio compares. The biggest difference is 1st gear. For a performance car, the recommended 1st gear output ratio is 10. M22Z 1st gear final drive ratio = 10.01 2nd gear final drive ratio = 6.85 3rd gear final drive ratio = 4.93 4th gear 3.36 Current M20 1st gear final drive ratio = 8.47 2nd gear final drive ratio = 6.31 3rd gear final drive ratio = 4.91 4th gear 3.36 What do you all think about this swap?
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery |
I am missing something here. I have a M22Z in my 71 - drove it last night. With 2.93's and 225-70-15's I am around 2,100 rpms at 65. The idea of this trans is a 5 speed gear spread (0.82 OD) with 4 gears. They originally meant the trans to be used with 3.08 gears (very common).
Your 3.36 with wide ratio trans is a good around town with occasional highway use. My friend's 70 Camaro has a ST10 with 3.31's so I know how it feels. I am wondering how your clutch is having issues; Dale's Camaro does fine - maybe a better McLeod clutch? |
For a street driven car, for optimal performance you want your first gear final drive ratio (trans gear x rear end ratio) to be between 9 and 10. Anything over 10 and the car will be less desirable for street application and more for strip in my opinion. Any thing less then 9 you will have to slip clutch. So a m20 with a 2.52 fist gear and a 3.36 rear the final drive ratio is 8.46. It is ok but I would rather have a little more first gear to make it more fun. I would rather be in the performance area and with a 2.98 first gear, it would put the final drive ratio 10 perfect for performance.
Moving the car with the 3.36 gears and the m20 is fine. however I live in the mountains and we have some steep hills that you have to pull out from a stop. It is a little hard on the clutch because you have to slip it some to pull out. The 2.98 first gear would help me on that as well. Your 2.98 first and 2.93 is 8.73 which is better then I have now and closer to that 9. The M20 with 3.55 rear gear would probable have been perfect for me but I would have higher 4 th gear rpms then. With the m22z the 4th gear rpms stay the same that I have now. Your friends ST10 may have a 3.42 first gear with a 3.31 rear. His final drive ratio in 1st is 11.32 wow. now that is very steep non street 1st gear. he barley moves before he is shifting from 1st, If he as the 2.64 first gear, then his 1st final output ratio is 8.73 which should feel like yours. Also you may have more lower end torque to help you as well. By the way, I contacted Paul Cangialosi at 5speeds.com and he thought the m22z would work great for my application.
68 400 HO 4sp Convertible Firebird400HO.com My 68 firebird 400 HO convertible Restoration Gallery Last edited by silverbullet07; 04-01-2017 at 09:11 AM. |
The M22Z gearset sounds like a nice spread for a big Pontiac engine.
Is it possible to install these gears in an original M20/M21 case? (I would like to keep my matching-number trans case...).
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Note: I bought mine at 5speeds.com form Paul. Only issue was fitment of the output yoke - my stock one did not fit. Buy one of his fitted.
My shifter is real close to the tunnel side. The top mounting bolt is right against the tunnel which does not allow much wiggle room. How is your shifter mounted? I have the adapter plate on hurst competition shifter. Not using athe c-clamp mounting plate. Trying to think all these things through.
The nice thing about these trans is that they are completely backwards compatible - the GM stuff bolted up. Only difference is that the SuperCase is a bit thicker at the mount ears, requiring special bolts and the speedo is passenger side ala Chevy. Another post after install: http://forums.maxperformanceinc.com/...highlight=M22z |
My 68 Muncie has the speedo on the passenger side. Must have been a 68 thing or earlier. Thanks for the link on your after install.
Far as I know...........all new housings 27 or 32 spline are all passenger side speedometer.
http://www.5speeds.com/cart/index.ph...5_17_69&page=2
I drove my Firebird for years with 3.55:1 & an M22; 2.2 x 3.55 = 7.81 I did not have to slip the clutch... It drove fine. I'd wager it has more to do with the torque curve than pure calculated nubers, otherwise Pontiac would never have made the base '73 Trans Am drive train as the M21 with 3.42:1; 2.2 x 3.42 = 7.524 I personally would stay away from too deep of a first gear combined number - it makes first gear kinda useless - but then again, that seems to be the norm for most cars; 2015 Camaro: SS w/6spd = 3.01 (1st gear) x 3.45 (FDR) = 10.38 SS-1LE w/6spd = 2.66 (1st gear) x 3.91 (FDR) = 10.4006 2015 Challenger R/T = 2.97 (1st gear) x 3.90 (FDR) = 11.583 2015 Mustang Performance Pack 3.657 x 3.73 (FDR) = 13.640 ...and even my Cobalt (which makes over #300 pretty quick); 3.38 (1st gear) x 3.82 (FDR) = 12.9116
Yes that is good advice. when you had your Firebird with a 3.55:1 & an M22; 2.2 x 3.55 = 7.81 Did you live in the mountains and stop on very steep hills? I'm not sure what the terrain is like in Calgary, AB, Canada. Here in the blueridge mountains and were I live, there are some very steep hills and a stop sign at the top. the m20 2.52 and 3.36 is ok for that but 3.55 would help. I would hate for the rear end to have lower numerical number like when I had 2.73 gears in.I burned the clutch all the time trying to pull out. Put two people in the back seat and the clutch would be smoking. Maybe may clutch was not adjusted correct but with a ratio of 6.87 it seemed bad.
Hense "taken with a grain of salt";
I will not argue with anyone that the 2.20 1st gear with a 3.55: was less than ideal - but it was offered that way from the factory more than once - I just chose the lowest hp & least ideal gear combination (1973 L75 & M21) as the worst case in which Pontiac offered it. This was also the standard gear combination that the 1971 & 1972 Trans Am's came with. Like I said, I suspect that torque is the key factor in making this less than ideal combined first gear ratio liveable - it would probably be painful for a low compression 400, and even worse in a 350.
