Old 04-02-2017, 08:06 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Default Temporary nitrous cam question
I have a solid roller cam (erson 302-7) @ .050 276-284 450 lobe on in. 430 lobe on ex. 1.8 RR cam on 106 LSA. My question is will this cam work ok, on a temporary bases, take a few nitrous hits safely? I would rather run N/A but a streetable pump gas 1000 hp might be too rowdy for me.
There is a local street racing class at Richmond Dragway and to thrive on the list I will need another couple hundred HP. ( My N/A pontiac is just a little short on hp to run with the top dogs with nos, blowers and turbos.)
My current cam in the car is @ .050 264-270 740- 740 with 1.8 RR on 110 LSA. It is installed 2* adv.
Steve
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', [email protected] 1/8 mi. 5.67@123 on small shot.
Old 04-03-2017, 09:28 PM
frbformula's Avatar
frbformula frbformula is offline
How big of a shot?
Old 04-04-2017, 09:51 PM
p4msi1's Avatar
200 shot
Old 04-05-2017, 07:59 AM
frbformula's Avatar
I am by no means an expert with nitrous but i have run a 150 shot on a non nitrous cam many times with no issues. My buddy runs a 200 shot on his car with a non nitrous cam and has 0 issues (his is a sbc). I believe a nitrous cam just makes the most out of using nitrous and people generally run on when they have big shots 300+. I do not see a reason why you would have an issue with a 200 as long as it doesnt run lean and you use a good quality fuel. Make sure you ring end gaps are good and you may have to run a diffrent plug.
Old 04-05-2017, 08:03 PM
p4msi1's Avatar
I think I am good to go, too. My kits are good to 500 extra HP but I will not push it,
Steve
