Old 04-02-2017, 05:59 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
Default spinning fender bolt
Hello, I'm taking the fenders off my 67 GTO, got them all off with out issue...EXCEPT for the top bolt in the door jamb, it had 3 shims under it, but whatever nut is inside...is just spinning...no what? notch the end of the eyelet to give it a slotted end, so I can slide the fender forward? I've felt up and in behind, but I can't feel anything. HELP!!!
Old 04-02-2017, 07:10 PM
gtospieg gtospieg is offline
you could slot the fender but that won't solve the problem...cut the head off the bolt and then work on finding a way to remove the rest of it...you probably will need to cut into the door jamb to fix this because you need to be able to replace that bolt
Old 04-03-2017, 10:48 AM
pfilean's Avatar
pfilean pfilean is offline
Is there access to the backside from the air plenum on the cowl?
Old 04-03-2017, 05:56 PM
gassman_67's Avatar
Thumbs up
I haven't removed the cowl, but the dash is out, and there is nothing behind the dash. I guess the cowl is coming off. Fingers crossed
Old 04-03-2017, 07:16 PM
400 4spd.'s Avatar
You said it had 3 shims behind it, so that gives you enough room for an air saw blade to chop the bolt off behind the head. Hold the bolt head with vise grips so it won't rotate while sawing the bolt.
Old 04-03-2017, 07:31 PM
gassman_67's Avatar
I wonder if there is access behind the cowl??
Do the replacement bolt kitd come with those bolts too?
Old 04-04-2017, 10:47 AM
pfilean's Avatar
A bolt kit would not likely come with the cage nut. Sounds like your cage (was spot welded to the body) has allowed the nut to spin within the cage. You probably can't replace in with a like nut. And the slip in style won't work without cutting a slot in the cowl.
But if you find access to the back side in the cowl just reach in with a nut when you tighten the fender bolt. The cage nuts are used at the factory so assembly line worker won't have to waste time reaching in or in some cases he was no access to reach in anyway.
Old 04-04-2017, 11:14 AM
gassman_67's Avatar
I figured "another" loose cage nut....I can't wait to get the ones at the bottom of the firewall. I hope I can get access through the cowl and get a nut on the back when the fender goes back on.
Old 04-04-2017, 12:59 PM
Joel Koontz Joel Koontz is offline
Might consider using a Nutsert when you reassemble.
Old 04-04-2017, 01:07 PM
gassman_67's Avatar
like a wall anchor...cool idea !!
Old 04-04-2017, 01:56 PM
Keith Seymore's Avatar
...and to accommodate dimensional variation from vehicle to vehicle during the build.
If there was no variation then the "cage" would not be required and just a regular weld nut would be used.
K
'63 LeMans Convertible
'63 Grand Prix
Old 04-06-2017, 10:28 PM
1965gp 1965gp is offline
I've had luck angling the bolt when this happens. Perpendicular to the cowl it might spin but at a 45 or 60 deg angle it might not. Should be able to get a good angle after pulling those 3 shims
Old 04-09-2017, 10:39 AM
gassman_67's Avatar
I was able to jam a large flat screwdriver in behind to wedge the cage nut from spinning, and was able to back out the bolt. Perhaps fish out the nut, which I believe didn't drop far, and tack it back in place when I re-install.
Old 04-09-2017, 06:27 PM
pfilean's Avatar
Before you tack anything reread post #11. Keith has a good point.
Old 04-10-2017, 10:22 AM
gassman_67's Avatar
ok...then tack in a cage nut...great points
