Old 04-09-2017, 10:22 PM
grd777 grd777 is offline
Default need help on my rust repair
want to repair a part of the lower front of the reat qtr panel .looks like the outer skin is sandwinhed between the sub structure , how do i get the new one in
Old 04-10-2017, 01:59 PM
mrrat1 mrrat1 is offline
Not a pro but I would think you will have to cut higher into the 1/4. How high is the question no one can answer.
Make your patch to go above the drilled holes. Weld it on then cut off higher up.
Fix the structure behind then reweld the patch back in.
Old 04-10-2017, 04:25 PM
was thinking that also but still not sure if that will work
Old 04-11-2017, 11:08 AM
can you inspect thru the vent in the door jamb, or take out the rear interior panel?
