Old 04-18-2017, 02:24 PM
dreamta1972 dreamta1972 is offline
Default 61 Bonneville AC quandary
I'm working on a newly acquired 61 Bonneville with no history on the AC besides I can see condenser and drier have been replaced on this factory air car. It's empty of freon. What have most of you been doing? Fixing leaks and recharge with R-12?
repair leaks and retrofit to R-134? Not looking to change over to aftermarket,but it is an option. Thanks
Old 04-18-2017, 05:20 PM
lilabner's Avatar
lilabner lilabner is offline
Better off with R12, or Duracool 12A. I use Duracool and love it. Use their oil also. Been in my car for 6 years without ever needing a recharge. A can is only 6oz but is equal to 12 oz of R12. Use 4 1/2 cans of whatever you choose. With Duracool, Change over is easy, just oil and R134 fittings on high and low ports. I went the extra mile and converted to all o-ring fittings.
Old 04-18-2017, 05:21 PM
77 Canamman's Avatar
Repair what component leaks, draw a vacuum on system and let sit a few hours to ensure leak is fixed, then refill with R12 and oil if any was depleted. Enjoy 37 degree vent temps.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 04-18-2017, 05:35 PM
gary bennett's Avatar
gary bennett gary bennett is offline
buy yourself an electronic leak detector like i did for my 63 and fix as needed, mine also needed o-ring and the pressure hoses, both.
DBANDGB
Old 04-19-2017, 09:29 AM
Has anyone used the Duracool 12A? Sounds like a good alternative except for the flammability issue.
Old 04-19-2017, 10:32 PM
Engine-Ear's Avatar
didn't lilabner answer that?
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 04-20-2017, 08:18 AM
He did. I didn't catch it until I re-read and didn't wish to remove the post in case others had opinions.
