Old 04-25-2017, 01:19 PM
Dick Boneske's Avatar
Default Tripower Vacuum Connections
Does a '63 Bonneville convertible use manifold vacuum for anything besides power brakes, PCV, & distributor vacuum advance? I know the A/C-equipped cars use vacuum for the controls. How about the regular heater without A/C?
I'm building a Tripower for a '63 in California and need to know whether it needs the small vacuum line off the center carb tee. You can see the small vacuum line in the middle picture on this '62 setup I restored recently.
Thank you.
Name:	'62 Tripower Vacuum Linkage 004.jpg
ID:	452966   Click image for larger version
Name:	'62 Tripower Vacuum Linkage 006.jpg
ID:	452967   Click image for larger version
Name:	'62 Tripower Vacuum Linkage 001.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-25-2017, 01:56 PM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
My 62 is an A/C car, but my previous 62 had vacuum for the defroster flapper door only. I don't know about the 63.
Les
Old 04-25-2017, 02:14 PM
Probably the same for '63 as '62.
BONESTOCK GOATS
Old 04-25-2017, 04:18 PM
Stuart's Avatar
Stuart Stuart is offline
Did 1963 have two different styles of regular heaters? In 1961 there were Direct-Aire and Circ-L-Aire heaters; one was purely mechanical controls and the other had vacuum control for the flapper. I don't know how many years they continued those two options.
Old 04-25-2017, 09:06 PM
I asked the owner of the Bonneville to check if there is a vacuum line from the carb to the firewall.
BONESTOCK GOATS
Old 04-26-2017, 10:12 AM
Engine-Ear's Avatar
Dick (and Stuart), Circ-L-Aire heater requires a manifold vacuum signal. There should be one vacuum line heading into the rubber vacuum bulkhead and I think there is another vacuum line coming from the heater control that runs along the engine side of the firewall going to the round vacuum diaphragm on the heater box.
...do you have a '63 HVAC manual?
Not that I am the last word on any of this, but I have never seen Direct-Aire system on a US-built '62 or later DarkSider.
I HAVE seen this system on CANADIAN-built PRE-'63 Pontiacs, but again, never on '63+ examples.
(Dick, I had a chuckle when you clarified that this is a convertible!)
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 04-26-2017, 07:20 PM
Thanks for the replies everyone.
Matt, I'm glad the convertible comment amused you! I don't know why I stated it was a ragtop, but that's just the way my fingers guided me!!
Dick
BONESTOCK GOATS
