Old 04-29-2017, 06:59 PM
GruntedCatalina GruntedCatalina is offline
Default Teeth on a flywheel inquiry
I believe my old flexplatel is going and need a replacement. and wanted to know the teeth count on an old 63 or where I can get the info. I also wondered if the teeth count changed through the years or the bolt pattern of the fly wheel. just so if i do go into town I can get something that will match up if its not the correct year.
Old 04-29-2017, 07:49 PM
tom s tom s is offline
What trans does it have?If still the slimjim it is a flywheel and not a flex plate.The only thing that changed on pontiacs is the ring gear location and the crank register diameter.Tom
Old 04-29-2017, 11:10 PM
its a TH400 trans.
Old 04-29-2017, 11:22 PM
Is this the one you are using without a adapter on a 63 block?Tom
Old 04-29-2017, 11:25 PM
yep. it worked out alright for a little while but its not matching right. probably never did. after the issues i had and after the previous owner, it took its toll on the flywheel so trying to get a correct one.
Old 04-29-2017, 11:52 PM
correct block?
