Old 05-03-2017, 10:45 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Default Help with TH400 Questions
Have decided to put a TH400 in my wife's 68 Convertible mated up to the new 400 I will be building. Although I have had several automatic Firebirds over the years (mostly 2nd gens with TH350s) and one 69 GTO with a TH400 it occurred to me its been so long I have forgotten some things:
1) For the downshift or passing gear, all I need is a kickdown cable correct? One that connects to the carb linkage. Someone I talked to mentioned a kickdown switch that can be installed at the accelerator pedal? Not sure I'd heard of that before.
2) Can anyone provide specs for the stock torque converter I should be using. When we installed the now crapped out 2004R I re-used the existing flex plate so I just need a torque converter that will fit the TH400 and bolt to my Pontiac flex plate. I believe the stock diameter was 12.5" but can't recall stock stall speed, number of bolts that connect to the flex plate (3?), I believe their called pads? Any help selecting the right torque converter is appreciated.
Specs:
1968 Firebird
YC Code 400 building it to 325-350hp
3.55:1 rear end ratio
235/45/17 tires on 17" Year One Rally IIs
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 05-03-2017, 10:58 PM
TH400 does not use a kickdown cable like a TH350 does, it uses a kickdown solenoid actuated by a switch mounted either on the accelerator pedal of the carburetor.
A 13" converter was used with 3 bolts holding it to the flex plate. Stall speed was somewhere in the 1500 to 1800 RPM range.
The TH400 uses a different yoke (32 spline) than the TH350 and you'll need to shorten the driveshaft by about 1" or a little less if you're using the TH350 driveshaft.
Old 05-04-2017, 01:33 PM
Thanks B-Man, I will have to research the kickdown solenoid. Think I'd prefer to mount it to the accelerator pedal. If anyone has a reference where to get one of those, let me know.
Current driveshaft was setup for a 2004R. Don't remember what the yoke is for that transmission, I'll have to look it up. Since the 2004R is also a longer trans the driveshaft may already be the right length but I may have to change out the yoke.
If I picked up a Torque Converter with a stall at 2000-2200 rpm how would that compare to the stock stall you gave me? I have some articles queued up to read. I never have been able to get my head around the concept of a stall speed.
Jimmy
POCI - AAC
Old 05-04-2017, 04:06 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
It also uses a different cross member.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 05-05-2017, 02:46 PM
True! Fortunately, I have a friend that adapted his 2004R to a TH400 cross member so we are just going to swap. The one I have is custom and allows you to remove the pan without removing the crossmember.
Jimmy
POCI - AAC
Old 05-05-2017, 09:08 PM
wovenweb's Avatar
wovenweb wovenweb is offline
The correct kickdown switch for a '68 Firebird mounts to the carburetor.
They've gotten much harder to find over the years. There was a gentleman who advertised in Smoke Signals, Tim Doonan, who used to rebuild them. Maybe check with him?
Old 05-05-2017, 09:50 PM
Jimmy,
Check with Cliff Ruggles if you're looking for a good converter. He can supply a 13" converter that drives pretty much like a stock converter (no excessive slippage) until you nail the throttle.
Myself I'm about to install a 13" Continental converter that I had built about 18 years ago and used for about 30K miles in a daily-driver '64 Tempest equipped with a 455/TH400/2.56 rear. I had it refreshed by Continental back in 2015 not long before the owner retired and closed the doors, I'm about to install it behind a fresh 421 backed by a TH350. Cliff used to offer Continental converters and has recently found a very good converter builder to fill the void.
Good luck, Bart
Old 05-05-2017, 10:39 PM
wovenweb's Avatar
The Parts Place is selling this:
http://www.ebay.com/itm/1967-69-Pont...3D271949920322
In the past, they were using a different switch. I think the key is whether the switch is normal open or closed. I've asked a couple people I know back in O-HI-O if they have an extra switch lying around. These would be rebuilt originals and won't come cheap if they have one.
Old 05-10-2017, 03:49 PM
Thanks, I would like to have a correct original. I will chat with you about it at the meeting tonight.
Jimmy
POCI - AAC
Old 05-10-2017, 04:00 PM
Jimmy,
Good luck, Bart
Thanks Bart!!
Jimmy
POCI - AAC
