Old 05-04-2017, 11:09 PM
JLMounce JLMounce is offline
Default Which valve covers
...to clear full roller rockers and that will fit under the wiper motor and large diaghpram power booster?
Seems simple but I'm not finding much unfortunately. I have a set of old Holley - M/T finned covers and they are just a bit too short and end up riding on top of the poly locks.
A standard 3.5" valve cover should clear the wiper motor theoretically and provide room for the rockers, but won't clear the power booster.
Do you guys have any recommendations?
-Jason
1969 Pontiac Firebird
Old 05-04-2017, 11:18 PM
tom s tom s is offline
I run factory 69-70 style covers with 1.65 H&S rollers with a 400 lift cam and the 5/16 after market gaskets.No issue with the large booster in 69 birds or 69 GTOs.Tom
Old 05-05-2017, 12:04 AM
Do you know the inside height on those valve covers?
-Jason
Old 05-05-2017, 07:37 AM
I have the 1.5 rollers under stock chrome covers with two gaskets. it's been that way for 10 years without leaking.
Old 05-05-2017, 08:50 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
X2 on trying the fat gaskets
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 05-05-2017, 05:07 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
I have valve covers from here.
http://tinindianperformance.com/pont...e%20covers.htm
Here are mine
http://forums.maxperformanceinc.com/...ghlight=covers
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 05-05-2017, 07:02 PM
Hikin Mike's Avatar
Stock chrome valve covers with 1.65 RR. No issues here.
- Mike
Old 05-05-2017, 07:37 PM
goatless's Avatar
goatless goatless is offline
Another guy that runs Scorpion roller rockers with stock repro valve covers and thick gaskets.
1966 GTO
Old 05-11-2017, 04:49 PM
68400BIRD 68400BIRD is offline
Same here. Scorpion roller rockers with stock repro chrome valve covers and thick valve cover gaskets. No problems.
Old 05-11-2017, 06:29 PM
76TA462 76TA462 is offline
I am using the Tomahawk finned covers with thick gasket. Tried the chrome tall covers, but it hit the brake booster. The Tomahawk slopes down to the front and back, and clears my roller rockers..
