Old 05-22-2017, 10:55 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Default Detail Item - Body Plug on Cowl
Can anyone tell me what is correct here for a '68 Firebird? The .5" hole to the right of the fender mounting point.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 05-23-2017, 07:40 AM
silverbullet07 silverbullet07 is offline
What I took out was a 1/2 rubber body plug like this.
https://secure.amesperf.com/qilan/De...A&web_access=Y
Old 05-23-2017, 01:07 PM
Ok cool. I have those and was thinking that was probably it. If anyone else can confirm this, please let me know.
Jimmy
POCI - AAC
Old 05-23-2017, 04:26 PM
A Schab A Schab is offline
I think that 67/69 use a hard plastic plug and the 70 up use the rubber plug.
Old 05-23-2017, 05:09 PM
Yeah it was a hard plastic plug I pulled off the passenger side but the plug for the driver's side was missing. Lots of parts have been swapped on this car so that's why I wanted to check.
Jimmy
POCI - AAC
Old 05-24-2017, 10:19 PM
Jason Rogers Jason Rogers is offline
Please tell me I can put that plug in without taking the hood and fenders off. : goes out to garage:
Sent from my SM-G860P using Tapatalk
Old 05-24-2017, 10:28 PM
Should be able too. There is also one on the door jam behind the fender that needs a plug. I missed getting those in.
Old 05-25-2017, 01:44 PM
Ames has the correct plastic plug (I think). I am going to order two. Part number is FP525. Silverbullet I see the holes in the door jambs and mine are missing there too. Not Surprised. I measure those at 3/8" though whereas these are 1/2" so maybe the same plastic plug but a different size.
Jimmy
POCI - AAC
Old 05-26-2017, 10:11 AM
All four of these are accessible after assembly. Phew.
Old 06-06-2017, 12:27 PM
The one in the passenger hinge is for the antenna to get into the car right?
