Old 05-25-2017, 03:06 PM
74gto's Avatar
74gto 74gto is offline
Default How to paint aftermarket pannel
I did do a search, but could not find the answer to my question, although it's been answered many times before. How do you guys prep an aftermarket fender that has the black e-coating on it?? I'm using base/clear as my paint. and was wondering if you guys scuff the black coating, prime and sand primer, and paint?? Or what is the correct process with certain grit sandpaper?? Any help appreciated.
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 05-25-2017, 05:30 PM
gary bennett's Avatar
gary bennett gary bennett is offline
me, i would strip to bare metal, clean with solvent, epoxy primer, sand , base & clear.
DBANDGB
Old 05-25-2017, 08:24 PM
400 4spd.'s Avatar
There are different schools of thought on prepping new parts with EDP coating. Some do like described above. Some (collision) shops will barely scratch the surface and shoot paint directly over it.
Our process is closer to what Gary does. We thoroughly sand the part with 320 grit until totally dulled. Then it's cleaned with solvent, followed with a coat of epoxy primer. Because PPG DP epoxy primer has a re-coat window of several days, the next day it gets a coat of high build primer on top of the epoxy. That holds it until it's time to sand and paint.
Old 05-30-2017, 10:17 PM
MUSLCAH MUSLCAH is offline
You can scuff up the e coat with 400.... leaving all the e coat on....then wash the panel with a water based cleaner...apply a coat of sealer...wait 30-45 minutes and refinish....NO Sanding....or you can do as above ....with the epoxy and high build primer if you a looking to block it out ,to make it lazer straight...
