Old 05-28-2017, 08:07 AM
CanAmT/AGTO CanAmT/AGTO is offline
Default 71 Interior Question Door Panel
Guys I am replacing the door panels (Custom) in my 71 what are the correct type of screws used to attach the lower carpeted area to the door.
The screws I removed had a large SEM type washer and I do not believe those are correct, so I thought I would check with the SME's (Subject Matter Experts)
Thanks in advance
Larry
I Bleed Arrowhead Red,
64 GTO 389 Tri Power 4spd Nocturne Blue Poly
70 GTO 400 4spd Palladium Silver
75 T/A 400 4spd Buccaneer Red
71 T/A 455 4spd Cameo White
01 T/A Bright Red 4L60E Ram Air WS6
02 TA Navy Blue Metallic 6 spd Ram Air WS6
Old 05-28-2017, 02:10 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Lower door panel screws should be chrome with a large embossed washer. The same screws were also used for the kick panels, seat backs and sail panels.
Old 05-29-2017, 07:00 AM
Dens71TA, Thank you for the info
Old 05-29-2017, 08:32 AM
Norwood's Avatar
Norwood Norwood is offline
Rarely do I disagree with Dens71TA but the 4 screws along the bottom of the door panel are of this design. The screw Den shows is used on the kicks and the sails as stated.
Old 05-29-2017, 02:18 PM
Dens71TA's Avatar
Not on my '71 or others I've seen at cars shows or in the salvage yard. My car has the deluxe/custom interior as does the OP. Have seen the other style on standard interior cars.
Old 05-31-2017, 07:14 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
...I'm with Norwood on this one...
ID:	455949   Click image for larger version
ID:	455950   Click image for larger version
Old 05-31-2017, 07:43 PM
Norwood's Avatar
I have taken apart all kinds of 60s and 70s GM cars and to the best of my recollection all have used the style screw that I posted in this application. I never say never but thi is my observation. Here are mine from my 70
Old 06-01-2017, 12:04 AM
FrankieT/A's Avatar
Another vote for Norwood here!
Old 06-01-2017, 05:44 AM
Judge273's Avatar
Judge273 Judge273 is offline
My original 71 deluxe door panels have the screws Norwood posted. Or custom ones with carpet...
Mike/Illinois
Old 06-01-2017, 09:36 AM
stich's Avatar
stich stich is offline
Yup,after 40 some years in the upholstery business, those are the correct screws for the lower doors. And I was doing them when they were "new".
