73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 06-04-2017, 04:55 PM
Tracto-man Tracto-man is offline
Default Battery dimmensions, '73 gto owners
Pulled the battery from my moms car and the GTO fired right up with some gas in the carb. So I need to buy a battery but theirs no battery box in there.
Could anyone get me some approx dimensions for the battery, and/or battery box?
Also, is the battery box/tray from the '73 LeMans the same as with the gto? Probably should buy one.
Thanks!
Old 06-04-2017, 05:58 PM
carguy66cars's Avatar
carguy66cars carguy66cars is offline
'73-'77 Lemans, Grand Prix will work, nobody offers a re-pop though. I may be able to come up with another used one if you can't find one?
Lyn.
'72 400 M22 4-speed Lemans Sport GT
'72 400 4-speed Luxury Lemans
'72 Luxury Lemans 4dr. hardtop 45,000 mile car
'72 Lemans 2dr. 20,000 mile car [sold]
'73 Grandville backhalfed Drag Car
'73 Grand Am 400 4-speed
'74 Lemans Sport Coupe-4800 original miles
Old 06-04-2017, 10:49 PM
I had 2 battery tray left NOS , & last year I sold both of them for $ 65.00 each, no one makes them & even the used ones are going for big bucks. Also the battery trays for the LeMans are the same. The one for the Grand Prix is different , but can be used if you have nothing else.
Old 06-04-2017, 11:18 PM
I'm thinking if its fairly simple I may be able to cab a simple one for now at least just to keep the battery from jumping out. If worst comes to worst I may see if you can find one. Happen to have any pictures of a battery box from those years? I'd like to pick up a battery tomorrow so approx dimensions would be awesome.
Thanks!
Old 06-05-2017, 12:08 AM
Should take the same Group 24 size battery that was commonly used for most American V8 cars built during that time frame:https://www.walmart.com/ip/EverStart...ttery/28275656
Old 06-05-2017, 12:14 AM
Grand73Am Grand73Am is offline
Group 24 battery with top posts is what I use. Fits perfectly. Here's one at Autozone, which also shows dimensions: http://www.autozone.com/batteries-st...64356_908277_0
Steve F.
Old 06-05-2017, 06:38 AM
Here's a picture of what they look like! I have several N.O.S. one's and there is even two different style's which I didn't know till last year! I don't have any used right now, but like I said I can probably come up with one?
Lyn.
Name:	'73-'77 Lemans battery tray 001.jpg
ID:	456248   Click image for larger version
Name:	'73-'77 Lemans battery tray 002.jpg
Old 06-05-2017, 09:52 PM
Thanks for the battery size guys! Exactly what I needed to know?
What would your price be for a batter box/tray?
Thanks!
Old 06-06-2017, 01:16 AM
You say there 2 different trays, can you tell me what the difference is as the parts books only show 1 & I worked in dealers fro 33 years & didn't see any difference in the 73 A-body Pontiac battery trays. Now the ones fro the Buick's & Olds & Chevy's are different but the 73 Pontiac A-body shows only 1 . ?? Please show me the difference if you will , I'd like to know the difference's. Thanks
Old 06-06-2017, 07:45 AM
Here are picture's of the two different style tray's and the one I pulled from one of my '74 Sport Coupe's! I had never seen the one without all the hole's until I bought a couple N.O.S. one's and then pulled the original tray from my '74? Not sure if there were two supplier's or if GM made a change at some point? Tracto-man I will let you know on the used tray.
Lyn.
Name:	Battery Trays 001.jpg
ID:	456365   Click image for larger version
Name:	Battery Trays 002.jpg
ID:	456366   Click image for larger version
Name:	Battery Trays 003.jpg
ID:	456367   Click image for larger version
Name:	'74 Lemans Battery Tray 001.jpg
Old 06-06-2017, 10:05 AM
Lyn, is the place for the hold down rod in a different spot on the one with holes than the other one?
(or just camera angle)
Old 06-06-2017, 02:39 PM
77 Canamman's Avatar
I've only seen the version with all of the holes prior to Lyn's pics.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 06-06-2017, 06:24 PM
John the hold down is the same, just the picture make's it look that way? Here are couple more picture's of the tab that was welded on the core support side that were tack welded on, not sure what it was for? Had to grind the weld's and knock this piece off?
Lyn.
Name:	'74 Lemans Battery Tray 003.jpg
ID:	456390   Click image for larger version
Name:	'74 Lemans Battery Tray 005.jpg
ID:	456391   Click image for larger version
Name:	'74 Lemans Battery Tray 002.jpg
ID:	456392   Click image for larger version
Name:	'74 Lemans Battery Tray 004.jpg
Old 06-10-2017, 11:57 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I measured my original 1974 side terminal Delco R89. It is 10-3/16" L x 6-3/4" W x 8" H. (Using a tape measure)
The height does not include the caps.
Official group 24 dimensions includes the caps,.
Group 24: 10.30 L x 6.80 W x 8.90 H
http://www.pontiacpower.org/
Old 06-11-2017, 09:58 AM
Horst,
Do you have pics of your original battery?
Old 09-17-2017, 09:58 PM
fiedlerh's Avatar
Yes. Here is the label.
I need to take a pic of the battery. it's like the repros, but the caps are gray.
Old 09-21-2017, 11:00 AM
1973ramairman's Avatar
1973ramairman 1973ramairman is offline
There is a battery tray available at Franks Pontiac parts $55 bucksClick image for larger version
