Old 06-09-2017, 08:33 AM
chaz069 chaz069 is offline
Default New Gasket for A/C Ductwork 67 gto
Looking for A/C seal for a 67 Pont GTO. A pillar, passsenger side. Evaporator to body panel , lower passenger floor. This seal prevents condensation or cowl leakage onto the passenger floor. A bracket holds the ductwork and seal in place to keep out moisture. Thanks chaz069
Old 06-09-2017, 05:02 PM
Jeff Hamlin's Avatar
Chaz,
I'm unaware of any aftermarket "Pre-made-cut" seal.
I've used 3M Strip Caulk in the past or an equivalent type dumb dumb putty will also work.
