Old 06-09-2017, 08:46 AM
chaz069 chaz069 is offline
Default 67 gtoA/C Ductwork seal
Need info availability on a ductwork seal on the A pillar passenger side lower floor area, just above the footwell. This seal and a bracket keep the moisture and cowl water from leaking onto the passenger floor. The evaporator is located in a cavity that normally holds the fresh air controls( lets in outside air). This seal is in a support bracket between the body and A/c ductwork. Thanks chaz069
Old 06-09-2017, 05:05 PM
Jeff Hamlin's Avatar
Responded in Heating-Cooling.
