Old 06-19-2017, 05:01 PM
Frank69 Frank69 is offline
Smile Power seat hookup to fuse block
Have the 40w breaker and the factory lead to P Seat harness. Plugged in the breaker and hooked up the lead. Found the panel connection in the fuse block is not hot! What has to be done to power up this connection? Manual says this breaker serves the P windows, P Seat and Convertable top. Have no Pw or Ptop but do need power for seat!.. Any ideas or suggestions would be appreciated.
Thanks, Frank69
Old 06-20-2017, 09:07 AM
What car?
Figure it must be a 1969 year?
Which fuse outlet trying to use?
I don't have a schematic off hand for the power seat for a 69 car.
How are you checking for voltage at the fuse box?
Old 06-20-2017, 09:36 AM
Smile
Thanks for the reply. Car is a 69 Firebird I have owned since 1979. Am installing power seat assy and manual says the 40w breaker in the fuse block supplies power to Pwindows, Ptop, & Pseat. Everything on the fuse block seems to be hot but the connection for the Breaker & the Seat feed line to the seat. Car has no power windows, ptop or pSeat from factory. Factory must have not connected this connetion. Have a voltage tester that lights on all the connections in the block except this one. It has never been used and have a new 40W breaker and power line to the seat. Plugged it in and no Power. If I have to find an alternate source of power what would be best choice. Not sure I want to take the fuse block apart- looks tough and is almost 50 yrs old! Have assy and also a maintance manual but not much help. Shows the block and conn for the breaker . Just thought the conn would be hooked to power. Thanks for your help and advice.
Frank69
Old 06-20-2017, 03:28 PM
I'ld run a new wire inside to power the circuit breaker. From battery + post, back of alternator, etc...
From memory, diagrams lost in a computer crash, most power top/power seat cars had a seperate power wire coming off a junction block under the hood. Then going into the back of the fuse box. Seems like it was a heavier guage wire than what goes in for everything else.
I suspect if you try adding power seats to an existing power source under the dash.....you'll have a melt down at the terminals in the bulkhead connector.
Be easy enough to hang your circuit breaker up out of the way. If your circuit breaker doesn't have 1/4" male blades, part stores carry them. then just use 1/4" female spade terminals to attach your wires.
Let us know what you decide to do
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 06-20-2017, 05:35 PM
You did check for power with the key on?
Old 06-20-2017, 05:50 PM
Here's a fuse box pic:
Are you using the fuse spot at top left in pic?
Also does the spot where the red arrow points to have 12 volts?
Old 06-20-2017, 08:35 PM
Spot w/red arrow is dead. one page in the manual says "not used"
I am thinking cars w/ this power eq. have a diff harness.
Tks, Frank 69
Old 06-20-2017, 08:38 PM
Yes. dead no power when breaker pluged in.
Red arrow also dead.
Thanks, Frank69
Old 06-20-2017, 08:39 PM
Yes. Key must be on for seat to work.
Thanks, Frank69
Old 06-20-2017, 08:54 PM
Smile
Clay
Clay, I agree with new wire option. New wire same size as the wire lead that runs from breaker to the seat harness. Am using a breaker that plugs in a fuse holder like a fuse 40W. A fuse holder mounted near the fuse box under dash that would allow the power side from the Alt+ post wire to one side of fuse holder and other side would hold the seat lead and power the seat. Fuse holder I have in mind is very simple fuse holder with a connetion on each end.
Thanks for your help and do you agree I am on the right track w/wire layout?
Frank69
Old 06-20-2017, 09:02 PM
Here's what I'm wondering.
Try using a jumper wire from one of the other middle fittings and jump to the top middle where the arrow is pointing.
I think this will give that fuse/breaker area power?
If not do as Quick said and run a dedicated power wire to the power seat wiring.
Old 06-21-2017, 09:47 AM
Smile
Thanks John.. I think I will try the dedicated wire method to avoid a prob with the old fuse box. Know the seat will not be going through the ign. so it will be hot all time. Been lots easier if dealer had ordered this car with a power seat option. Also much cheaper.
Best regards, Frank69
Old 06-21-2017, 12:16 PM
If you want to go ignition switch controlled power for the seat....need to use a relay for the ignition switch to turn off and on supplying power to the seat. Most all high amp draw accessories use relays similar to high speed blower fan.
Seems like the last big Pontiac I had, power seat worked without ignition being on.
Yes your plan sounds good. As long as battery wires on back of alternator are same size or bigger than what you'll be adding. That would be for moving the seat when the engines off or alt not charging.
I would add a short piece of fusible link wire, on the end of your power wire, where it hooks to the back of the alternator. Same safety measures the factory would have used.
Clay
Poncho & Lefty
Old 06-26-2017, 09:37 AM
Smile
Hi Clay, Plan to use 10ga wire from alt to fuse. This seems to be the same as the factory wire feed I will use from the factory type 40amp breaker to the seat harness. Should I use l2 or 14 ga. fusible link wire from alt?: Going to leave the seat hot all time and not try to go through ign switch. If it worked in your ole Ponty it should work ok in mine. Thank you for all your input. Your the MAN!
Frank69
Clay
Old 06-26-2017, 10:57 AM
Four numbers smaller would be correct. With 10ga wire use a short 6" or so piece of 14ga fusible link. Shorter than 6" is fine but I wouldn't go longer.
For my own stuff; I solder spade terminals, on the fusible link and main wire, to make them easy to replace. Ring terminal on the alternator end. Just use good heavy duty terminals that'll stay connected tight.
Clay
Old 06-26-2017, 11:33 AM
Thank You!!
Frank69
Old 07-15-2017, 10:14 AM
Smile Manual to power seat trade out/69 Firebird
Thanks to all who helped me with this project.. Its so nice to have people to help when it's needed. Glad to report the power seat installation and operation is a success. The assy was orig 69 F-Bird that was completely restored and it looks good and operates well. Nice to have friends like you guys!
Frank69
