Old 06-19-2017, 10:49 PM
ejw's Avatar
ejw ejw is offline
Default DA front shock starting point advice/recommendation
Just finished tonight installing QA1 DA coilovers on front of my firebird. I have been searching online for recommendations on starting point settings for car.
Any body have any recommendations for initial settings.
3100lb car, 1700lb front. 550-600hp. w/ current 90/10 and coil spring setup was running 6.38 w/ 1.37 60'. Transbrake leave at 3000.
My friend said the car hits hard on launch (jumps) but bounce front wheels. I can feel it in steering wheel. Makes car temperamental on iffy track which stinks bracket racing.
Rear suspension has remained unchanged - calvert leafs, caltracs and shocks set on #4 (1 is softest setting).
Over winter I dropped 100+ lbs off front and freshened up engine and increased HP (which added 10mph and dropped .60 in 1/8. )
thanks
Old 06-20-2017, 07:01 AM
grandville455's Avatar
grandville455 grandville455 is offline
How the heck is that front so heavy with a total weight of only 3100? Is that with you in in the car? What does QA1 say for settings?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 06-20-2017, 10:10 AM
ejw's Avatar
ejw ejw is offline
Driver in car.
Rechecked records front is 1650 and car 3165
Didn't finish install until eve, qa1 closed. Call today
