Old 06-21-2017, 01:35 PM
War eagle War eagle is offline
Default 1959 Pontiac bellhousing inspection cover std trans.
Looking for a 59 bellhousing inspection cover and not real sure what it looks like. Found one thought to be correct but turned out to be for an automatic. Could someone post a pic and or know of one for sale? Thankyou. Rod
Old 11-01-2017, 11:29 PM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
If you mean the topmost one, here it is. If you mean the two pieces that go under the housing, gimmee a few days to figure out which pieces {I also have the pieces for a GMC housing] fit my bell housing.
Roll around in the excitement
Old 11-01-2017, 11:32 PM
Rocky 389's Avatar
Here's the front piece...I'll find the correct bottom pan in a day or so.
Old 11-02-2017, 06:25 AM
Rocky 389. I need the bottom pan. I found the front piece that you show. I appreciate the help.
Old 11-03-2017, 01:27 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Rocky- sent you a PM.
Old 11-04-2017, 11:05 PM
Rocky 389's Avatar
Here are photos of the 59 bottom cover pan. Easy to spot because of the single louver at the bottom...
ID:	466896   Click image for larger version
ID:	466897   Click image for larger version
Old 11-04-2017, 11:08 PM
Rocky 389's Avatar
The 57 GMC pan is quite a bit different. Same basic design but different enough it'd have to be redrilled a bit and some tabs welded on and drilled.
ID:	466899   Click image for larger version
Old 11-04-2017, 11:11 PM
Rocky 389's Avatar
BTW, I need the 59 pan for my project..not for sale but if you think you can use the 57 GMC pan, send me a PM.
Old 11-05-2017, 12:28 AM
Thanks for the pictures.
Old 11-05-2017, 09:18 AM
Thanks Rocky. Could you get us a pic of the cover on the bellhousing. I have a cover but seems to hang over the side edges of the housing a little more than similar chevies.
The 59 oil drain vent is good to see as well. My cover is the same. The GMC is more like chevies with a single 1/4 nch hole.
Old 11-05-2017, 09:44 AM
Rocky 389's Avatar
Mister Eagle: I'll be happy to click that photo as soon as grand kids leave. In the meantime, the cover fits the bottom of the housing flush...nothing hanging over.
Old 11-05-2017, 10:51 PM
Rocky 389's Avatar
This is the pan bolted up with 2 bolts. Sorry for the sad quality of the photos but I was taking photos from the floor with florescent lighting overhead...tricky to say the least. Hope this answers your questions .
ID:	467014   Click image for larger version
