Old 07-09-2017, 01:15 AM
goatman65's Avatar
Default puddle in intake
Tripower, end carbs blocked. After shutting engine off if I look in the intake there is always a puddle of gas forming under the front carb. Obviously it is from the center carb, but why?
This is a new carb from JET. It is not flooding and no visible signs of anything wrong until I look into the intake.
Idle is 950
fuel press 4 psi
float 19/32
mixture screws 2 1/2 turns
no choke
No nozzle drip while running but it always seems like it needs to 'clear its throat' at idle.
Gas puddle forms whether engine is cold or up to temp.
Since this is a 'circle track' carb is it possible that it is 'supposed' to dunp a lot of fuel at idle?
I'm not sure if I should drive it like this or not. Odd thing is, even with so much gas in it the A/F gauge still reads lean, 15.? to 17.? at idle.
So what do I need to recheck?
Old 07-09-2017, 06:25 AM
steve25 steve25 is offline
That center Carb had a issue and at first I was going to say that it was just today's Alky cut fuel boiling over when hot, but you say you have to clear it out to get good responce when at idle.
In short that Carb has a internal issue that you need to get fixed fast as all of that excess fuel is likely washing the needed lube oil off off the cylinder walls and waring the motor out fast, no less it could be diluting the oil also!
Old 07-09-2017, 11:41 AM
Scott65's Avatar
Scott65 Scott65 is offline
Don't they have well plugs that are capable of leaking? Been awhile since I had one apart. Maybe have a look at that.
