1965 or 1966 421 Engine Block
I have a 1965 - 1966 421 engine block for sale . It is coded YJ part# 9782611 which originally was a 356 HP,tripower,10.75 compression ratio auto trans engine . The #s by the YJ on the front of the block are 053416 . The date code is something 5 ( I can't make out the first part) . It has 4bolt main caps . The block has been hot tanked and magnafluxed . I believe it to be standard bore with a small ridge on top of the cylinders . It has slight surface rust on it . It was tanked approx. 3years ago . It is located in Elliston Virginia . It can be picked up there or I can bring it to Norwalk or Fall Carlisle with me . I'd like to get around $1600 for it . I will also throw in a used 9783787 arma steel crankshaft in unknown condition , a used set of rods and pistons ,oil pan and baffle . Thank You Don
