Old 07-17-2017, 07:43 PM
1NC Again 1NC Again is offline
Default 72 Lemans Horn Relay
Its been 3+ years since I took out the dash and wiring harness on my 72 Lemans Sport convertible. Dash is back in with Dakota Digitals and a new M&H wiring. The horn relay is plugged into the proper connector BUT I can't remember where the connector mounts to under the dash. I'm limited by wire length, but can't find the right 2 holes for the mount screws. Can someone send a pic of where it mounts? THANKS !!
Old 07-18-2017, 06:51 PM
Thanks for your reply Scott, but no mount provisions (screw holes) over the booster. I know the 71 relay is over the booster, but the wires are going more than a few inches from the steering column in my 72. Anybody out there with a 72 with the relay under the dash?
Old 07-18-2017, 08:22 PM
redgoated redgoated is offline
Just got my 72 dash back from Just Dashes. two holes just above the lower dash mount hole.
Old 07-19-2017, 05:14 PM
Thank you !!
