Old 07-26-2017, 11:00 AM
Groucho's Avatar
Groucho Groucho is offline
Default Who knows 74 GTOs?
I wanna lighten mine up. Can I put bumpers/brkts from a 68-72 Nova on my 74 GTO?? Don't worry, I'll save all the orig. parts. THX
Big Willie and Tomika's Street Racers
STUGOTS-SoCal
Adding more power since 1971
Old 07-26-2017, 11:22 AM
BILTIT's Avatar
BILTIT BILTIT is offline
No (well maybe but i dont think it will look good), but you can lighten the stock bumpers and get rid of the bumper shocks and move it in closer to the body.
Sent from my SM-G925W8 using Tapatalk
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 07-26-2017, 11:23 AM
BILTIT's Avatar
I have lightened and moved the front bumper in, still havent gotten to the rear but will eventually. Its amazing how much weight you can take out of these bumpers
Derek B.
Old 07-26-2017, 11:51 AM
Groucho's Avatar
I don't like the way the originals look. Very clumsy looking.
STUGOTS-SoCal
Old 07-26-2017, 12:17 PM
BILTIT's Avatar
The nova bumpers have a different contour so i dont think they would look good, imo.
Derek B.
Old 07-26-2017, 12:19 PM
BILTIT's Avatar
If you search posts by me, look for a minitubbing thread and you might see some pics of my front bumper moved in.
Derek B.
Old 07-26-2017, 12:48 PM
Rob B's Avatar
Rob B Rob B is offline
You can move them in but then it messes with the filler panels. Pulling the inner bracing from both the front and back bumpers, removing the 5mph mounts/shocks will net you some serious weight reduction. You can make your own brackets to remount the bumper "shells". My front bumper assembly now weighs around 35-40lbs with my new mounts attached compared to the almost 85lbs it was prior. And that doesn't include the 15lbs a piece for the OEM bumper shock mounts. Roughly the same numbers for the rear bumper. I've done this to both cars. The only way to go lighter is fiberglass. I have those for mine but haven't installed them yet. With those, I'll make aluminum mounting brackets to maximize the weight reduction even more.
There is a bunch of spots on these cars that you can lose some weight, just depends on what you want to do.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 07-26-2017, 12:51 PM
Rob B's Avatar
But back to your original question about 68-72 bumpers?? No.
There are a ton of subtle differences between the 68-72 X bodies over the 73-74 X bodies.
Old 07-26-2017, 02:27 PM
ponyakr's Avatar
ponyakr ponyakr is offline
I was told that the bumper on my '74 Vent was a Nova bumper. It was there, when I bought the car.
Name:	'74 Vent .JPG
ID:	459600   Click image for larger version
Name:	Nova Bumper.jpg
Old 07-26-2017, 02:35 PM
Rob B's Avatar
Thats a 68-72 Bumper. More than likely a Nova. 71-72 Venturas had a little bit of a curve to them, I think. But DEFINITELY not a late 73, 74 bumper.
Old 07-26-2017, 06:23 PM
Groucho's Avatar
That doesn't look bad to me at all. Better than the battering ram that's on mine now!!
STUGOTS-SoCal
Old 07-28-2017, 09:51 PM
Groucho's Avatar
weekend bump
STUGOTS-SoCal
Old 07-28-2017, 11:14 PM
se428bandit's Avatar
se428bandit se428bandit is offline
VFN makes a fiberglass front bumper, it weighs 4 lbs. http://www.vfnfiberglass.com/73-74gto.htm
