Old 08-19-2017, 07:04 PM
dcvp264 dcvp264 is offline
Default 455 rear seal problem
Hello new here ..thinking of buying an outstanding 63' GP with a very healthy 455 from a 76' Pontiac ..it is a beautiful car with one problem, it has a rear seal leak.. does the tranny have to come out to replace the seal.. or is it worse than just that..thanks for info
Old 08-19-2017, 07:18 PM
Stuart's Avatar
Stuart Stuart is offline
Yes, the transmission has to come out. I would imagine the oil pan has to come off and the crankshaft dropped out as well.
Having said that, how bad is the leak? If it's just a few drips I wouldn't be too concerned.
Old 08-19-2017, 10:58 PM
its more than a few ....not real bad but it would be a pain to live with for my driveway and garage
Old 08-20-2017, 01:02 PM
AZ64GP AZ64GP is offline
Unfortunately, this is a common problem among Pontiac V8s of the era. When I was rebuilding my 389, I purchased a Viton rear main seal. They are available from our host, as well as BOP Engineering and other places.
Better than the old rope seals and it can be installed with or without removing the crankshaft. You'll still have to remove the oil pan and probably transmission, but at least it saves you having to remove the crank.
Old 08-20-2017, 02:16 PM
would absolutely like to buy this car, it is a great car.. but I'm not capable of doing the job and the expense may make the car more than I want to spend .. I'll have to check around to see the cost but I think its going to get ugly....just a shot in the dark, does anyone know of a reliable shop that can work on a classic like this in the Buffalo NY area ...........thanks for replies ,..(love these sites)
Old 08-20-2017, 07:00 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I'm running the Best Gasket graphite rope seal, no leaks.
Old 08-20-2017, 07:22 PM
tom s tom s is offline
Not NY but you might check with Jim Pickett at Pickett automotive in NJ,he does classic car work.Tom
Old 08-21-2017, 09:22 AM
62cat's Avatar
62cat 62cat is offline
Picketts are outside of Philly PM me if you need there number.
Old 08-21-2017, 10:16 AM
thanks ..but thats about 500 miles from me
