Old 08-21-2017, 03:16 PM
Aaron65's Avatar
Aaron65 Aaron65 is offline
Default Got a Ranger Quickjack...
Actually, my dad got it for me for Christmas, and I just took him up on the offer. It's not bad for a guy who doesn't have the garage space or height for a real lift. When I'm done, I can just disconnect the hoses and slide them under one of the cars. Don't get me wrong, I'd love a full rise lift, but sometimes you have to make the best of your situation, and this isn't a bad alternative, especially if your dad is in a giving mood!
1974 Firebird Esprit
1953 Buick Special Riviera
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Skylark Sport Coupe
1965 Dart 170 Wagon
1965 Corvair Monza Convertible
The Following User Says Thank You to Aaron65 For This Useful Post:
Old 08-21-2017, 03:36 PM
Two_70_Converts Two_70_Converts is offline
Just got mine in as well a couple weeks back. So far I am loving it. Pump and cables store neatly on a shelf and lifts store under the car. It's very portable and I can throw it in the truck for the track. Also, where most lifts obstruct the center of the car, these leave it wide open for access. I wouldn't complain if it went a bit higher but so far hasn't been an issue.
Old 08-21-2017, 04:46 PM
Simple Man's Avatar
Curious, what does one of those run? Big $$?
be a simple...kinda man.
Old 08-21-2017, 05:42 PM
GT182's Avatar
GT182 GT182 is offline
I like that one Aaron. Except for height it's better than my scissors lift.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-21-2017, 06:02 PM
Old Goat Racer's Avatar
looks like it's tall enough to pull a tranny ?
Everybody knows somthin.
Nobody knows everything !
Old 08-21-2017, 06:04 PM
Blue1967GTO Blue1967GTO is offline
I've had Quickjacks for almost 2 years and they have changed my DIY life. It's also awesome that I can take them to the race track.
Check out my cruise night! www.brewcitycruisenight.com
The Following User Says Thank You to Blue1967GTO For This Useful Post:
Old 08-21-2017, 06:24 PM
https://www.summitracing.com/parts/q...e2-_-quickjack
Old 08-21-2017, 08:22 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
I got mine a few weeks ago..... Love it
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 08-21-2017, 08:27 PM
Aaron65's Avatar
I've pulled transmissions with less height than this, so I'd say you definitely could. The only problem might be not being able to pull it out from the sides, but that shouldn't be much of a problem on most cars. That's why I didn't get a scissor lift, even though they usually lift higher; everything in the middle of the car is totally open, so you can get to exhaust, driveline, etc.
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Dart 170 Wagon
Old 08-21-2017, 09:49 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Which size model did you get? I have the new, big 7000 model on order. Looks like that one is the best size for my 64 as well as for my Jeep. I bought the added "SUV extensions" which will lift it another 4" as I recall.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
Old 08-21-2017, 11:13 PM
Aaron65's Avatar
I got the 5000-SLX. I did some measuring, and I figured it was big enough for all of my stuff, plus it has a slightly lower profile than the 7000. I haven't yet lifted my Buicks with it though, so we'll see. They're by far the biggest cars I have. The weight shouldn't be the issue, however, but the length.
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Dart 170 Wagon
Old 08-22-2017, 07:20 AM
judgethis judgethis is offline
I got a little chuckle seeing all the card board on the floor. I remember when I was a kid and would see the card board on the floor when he was working on his cars. Sometimes having the car just that much off the ground will make a job easier, especially not having to get out the jack and jack stands. Happy wrenching!
Old 08-22-2017, 10:36 AM
GT182's Avatar
Question... Are there locks so they don't bleed down?
Gary
The Following User Says Thank You to GT182 For This Useful Post:
Old 08-22-2017, 01:03 PM
Aaron65's Avatar
Yes, there are locks. In fact, I tried to lower it yesterday with the locks engaged and it stopped immediately upon hitting the locks. It seems like a good setup.
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Dart 170 Wagon
Old 08-22-2017, 01:40 PM
1966Lemans's Avatar
1966Lemans 1966Lemans is offline
How flat are those things, when all the way down?
'67 Piper Cherokee
'66 Lemans
Old 08-22-2017, 03:04 PM
Aaron65's Avatar
I think it's about 3 inches tall. It fits under the Firebird easily.
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Dart 170 Wagon
Old 08-22-2017, 05:14 PM
lemansboy70's Avatar
lemansboy70 lemansboy70 is offline
Is there something I'm missing? How stable is it side-to-side? No cross-bracing?
30+ Years with NAPA. Happy to help with any auto parts questions.
Old 08-22-2017, 06:25 PM
Stuart's Avatar
Stuart Stuart is offline
There are two separate lift components, one on each side that aren't physically connected. However, think about if you put your car up on four jack stands, this is basically the same thing except instead of two jack stands per side you have one lift component. It's as wide or wider than a jack stand so the stability should be as least as good.
Old 08-23-2017, 05:32 PM
Thanks for the clarification!
Old 08-23-2017, 07:14 PM
tigergto's Avatar
tigergto tigergto is offline
I'm thinking of getting one but that 17.5 inches of lift height makes me a little unsure. The scissors lift for three to four hundred more has much more lift height.
