Old 08-23-2017, 09:44 PM
ta man ta man is offline
Default New engine combo with 3.08 gearing
I'm following the advice of a few other members and starting a new thread on my adventures with 3.08 gearing. I'm heading to the track Friday and Saturday to test the new engine. New shortblock is a 466,hardblocked to the bottom of the waterpump, crower billet steel rods, CP pistons(420g),total seal rings,Chyro'd crank, balanced assembly, o ringed,new Romac SFI balancer, new ATI SFI flexplate, canton 400 oil pan with an oil temp sender. Heads have been upgraded to SD Performance "CNC 305" package, also new comp dual springs,retainers,keepers.The heads have been milled to 79cc to set engine compression at 10.75 to 1.The OF cam has been swapped for SD's OF 2.0.The torker 2 intake has also been touched up also to match the heads.Running the same 950 hp Holley,1 3/4 inch Hooker Super Comps.Rearend has been upgraded to a Eaton Posi and Dutchman 30 spline axles but retain the factory GM ring and pinion.
Dave Bisschop figures the new engine should make between 30 and 50 more hp.The shortblock is an added bonus and may contribute some "extra" horsepower over the old shortblock due to better ring sealing and a much lighter rotating assembly.
I'm just wanting to see a sub 11 second pass first pass.The first goal I have is a sub 7 second 1/8th and a 100mph plus 1/8th.
Old 08-23-2017, 09:49 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Cool! Good luck and keep the updates coming.
Go fast, see Elvis!
Old 08-23-2017, 11:09 PM
71 T/A 71 T/A is offline
If it's a 30 hp gain, you'll run 10.70s. If it's a 50 hp gain, you could dip into the 10.50s.
We'll see.
Old 08-23-2017, 11:59 PM
surfsama's Avatar
surfsama surfsama is offline
Whatever you run have a blast and make it back in one piece!
Only a pawn in game of life.
Old 08-24-2017, 07:46 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Will try to come out hook up, be good to see what the car does. Great weather ahead.
Old 08-24-2017, 09:00 AM
Sounds good!We are staying overnight and running Saturday too!
Old 08-24-2017, 09:04 AM
We'll see.
Traction will be the key!
Old 08-24-2017, 09:22 AM
hal101's Avatar
hal101 hal101 is offline
what track are you running at ?
Old 08-24-2017, 09:34 AM
St Thomas Raceway Park..aka Sparta
Old 08-25-2017, 09:39 AM
hal101's Avatar
i was hoping it was closer im on vacation in cornwall on if it was closer i would like to drive over and see you run
Old 08-25-2017, 11:15 PM
Fought some traction issues on a few runs but final run of the night netted 10.77 and 126mph plus.
Old 08-25-2017, 11:28 PM
brut4s's Avatar
brut4s brut4s is offline
SWEET!!!
Old 08-25-2017, 11:39 PM
slowbird's Avatar
slowbird slowbird is offline
Nice mph! Get things sorted out and it might impress people, lol. Great job.
Old 08-25-2017, 11:59 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Bitch'n!!!
Shut it off
Shut it off
Old 08-26-2017, 12:18 AM
surfsama's Avatar
Man, you gotta love that!
Old 08-26-2017, 01:39 AM
Fatal Fatal is offline
Badass man!
Old 08-26-2017, 06:25 AM
So....30 hp gain?
Old 08-26-2017, 07:58 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
All of the hard work really paid off. Could go 10.50's this fall.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 08-26-2017, 08:58 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Wow...mph is crazy.
Does converter still feel tight?
Old 08-26-2017, 09:05 AM
hal101's Avatar
nice
