Old 08-30-2017, 01:15 AM
goatman65's Avatar
Default timing tape
Seeems like all the Pontiac timing tapes being sold are for 5-1/4 dia balancer, will it be ok to use on the 6.8 balancer? My balancer is already degreed but some of the markings are off a few degrees according to 2 dialback timing lights.
Old 08-30-2017, 02:43 AM
Kenth's Avatar
Kenth Kenth is offline
Do you have the correct timing cover (and scale) for your damper?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-30-2017, 06:24 AM
steve25 steve25 is offline
How does your balancer check with a straight up non dial back light?
Old 08-30-2017, 06:42 AM
johnta1 johnta1 is online now
The tape won't work on that balancer.
Try this:
Timing Mark Calc
If mark on balancer is at TDC, it will work.
Old 08-30-2017, 09:51 AM
ta man ta man is offline
I've never used timing tape. I put TDC at 16 adv at 4 retarded I mark the balancer, that gives me a 20 degree reference mark.
Old 08-30-2017, 04:05 PM
Squidward's Avatar
With the 6.8 I just estimate 16 degrees per inch for gross reality check, even tho it is a little closer to 17 degrees (16.85) per inch with more precise math. 16 is a pretty good number for initial timing.
TA Man, that makes an interesting concept for marking the balancer - just use the existing timing tab to mark off new marks with a sharpie. Timing tabs usually have at least 12-16 degrees displayed, and a highly paid engineer already did the math!
Old 08-30-2017, 07:33 PM
goatman65's Avatar
Timing cover is 1968 with 0-6-12. Zero on balancer is at tdc. I bought the balancer about 5 yrs ago, a PRP that had every degree painted on. It rusted pretty quickly, so when I had it off last year I derusted and painted it and used a dremel to engrave 'some' of the degree marks. I did 0-10-16-18-20-30-32-34-36-38 and 40. My dist at that time had 34-36 total and 14-16 initial. So I thought those degree marks would be fine. Well now I want to try 30-32 total but still with 14-16 initial. When I set initial at what I thought was 14 it is actually 17 when I turn the knob on the light. After doing a search for timing marks I measured my marks and found out that I have most of the marks off by a few degrees. So rather than confuse myself by trying to add or move the marks I already have I was going to cover them with a tape with nice readable marks and numbers.
Old 08-30-2017, 07:46 PM
I've had it that way for a few years on my KRE headed engines. Since they fall in the 28 to 32 total range normally, all I needed was a 20 degree mark, bring up the revs and note where it falls on the timing tab at total timing.
Old 08-30-2017, 08:25 PM
goatman65's Avatar
I recently put a set of KRE heads on my 467 and that is why I want to try around 30-32 total. But the engine likes a lot of initial,at least 14 but 16-18 seems better plus 7 from vac advance. If I turn the dist to get 30-32 total no vac, it has 10-12 initial. It hates 10 and 12 ain't much better.
Old 08-30-2017, 08:37 PM
Mines pretty good at 8 degrees initial ,it idles between 850 and 900rpm.
Old 08-31-2017, 02:13 AM
goatman65's Avatar
At 10 initial mine is harder to start,and I have to turn the idle screw in so much that I end up with nozzle drip at 950-1000 idle. But I think that might be a very lean idle circuit that I am finally getting straightened out ...I think.
Old 08-31-2017, 05:55 AM
Squidward's Avatar
10 is hard to start? Wow. I never would've imagined 10 would cause the starter to complain.
Old 09-01-2017, 12:13 AM
goatman65's Avatar
The starter has no problem turning the engine,the engine has to crank many revolutions before it will start with 10. With 14 or more it will start in 1 or 2 revolutions.
Old 09-01-2017, 06:18 AM
That has more to do with your air to fuel ratio with the motor cold then the timing changes!
Normal hot mixtures are in the 14 to 1 range , but a cold motor needs just about the opposite ratio to light off in 1 to 2 revolutions!
Old 08-27-2018, 09:52 AM
chrisp chrisp is offline
https://www.ebay.com/itm/10-pcs-Pont...UAAOSwqfNXjXqJ
Old 08-28-2018, 03:54 PM
ELKHORNAOG7 ELKHORNAOG7 is offline
Talking
If you have the book by Tom Hand about rebuilding Pontiac engines it is in his book about marking the balancers.----BOB
