If I let my 68 GTO sit more than a couple of weeks, I'm greeted with a sizable puddle of ATF under it. I'm told this is ATF draining back into the converter. Any solution to this, other than driving it more?
be a simple...kinda man. |
It shouldn't be leaking anything. My 69 G/P does the same thing. I've swapped out the torque converter and the converter to front pump seal twice. Still leaks. I figure it's either the front pump to trans case gasket/seal or the pump or case have a sand hole (porosity).
Could be wear at the front pump bushing, not a expert but did stay at a Holiday Inn once.
'68 GTO '69 Corvette '75 Cadillac Coupe Deville TOM |
I am no expert at this either, however had the same problem with my 68 a few years back. Huge puddle underneath after sitting for the winter. My buddy told me it's leaking around the dipstick seal. I replaced mine and sure enough, that took care of the problem. Hope this helps.
