70 gto 10 bolt
Hi guys planning to swap my 10 bolt rear for a 12 bolt rear car is a turbo 400 will the driveshaft be the correct length?
Yes, however you'll need a 3R to 1310 conversion u-joint.
X2. I just did this for my brother's car.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Is this true if you have a 12 bolt from a 70 GTO (as opposed to the more common Chevy sourced ones)?
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay" 1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always. |
No, not true, the original 12 bolts used in the '70 GTO's are direct bolt in, a have pinion flange that accepts 3R ujoint. Same deal with many other McKinnon built 68-72 12 bolts.
Also some trimming of one upper arm at the rear bolt hole will be necessary. |
