Old 10-06-2017, 12:37 PM
Joel Koontz Joel Koontz is offline
Default Airsoft Pellets for balancing tires?
I have read a bit about it and seen some Youtubes, but have not TT anyone who has actually done it.
If you have, please tell us how it worked
Old 10-06-2017, 01:22 PM
cdrookie cdrookie is offline
motorcycle guys like dyna beads, probably take a good bit to balance a tire though.
Old 10-06-2017, 04:39 PM
bdk1976 bdk1976 is offline
I picked up a large container of airsoft pellets at a garage sale a while back for $1, figuring I'd try this out sometime. Haven't had an opportunity yet, though.
Old 10-06-2017, 05:28 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
What would cause round beads to settle both on the side exactly opposite the heavy part of the tire radius or correctly on inner or outer aspect of the tire? Seems to me they will
Just roll around completely useless??
Steve
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 10-06-2017, 05:52 PM
I don't know if they work or not but I have definitely seen where a lot of people say that they do.
I have heard that the use them, or something similar, in 18-wheeler over the road truck tires???
And I've heard that you're used in tires on lifted trucks, 35 inch Etc.
But just because I've heard it, doesn't make it true, and that's why I was hoping somewhere that's actually done it would provide some feedback
Old 10-06-2017, 06:13 PM
JonW JonW is offline
Good reading here: http://http://www.innovativebalancing.com/news.htm
1963 GTO project
1975 LeMans Sport Coupe
Old 10-06-2017, 06:35 PM
Bluesugar Bluesugar is offline
You don't want to go there with the beads!!,..Myself and other members of our motorcycle
club tried these and they just make a mess of trying to balance at all speeds...Think about
it,..your gaining momentum from a standing start and the beads find their inertia on the inside of the tire,thats fine until you slow down or come to a stop, they mix all up again and fall where ever and the beads keeps trying to find their position over and over again!.
Once a set speed is going the beads do their adjustment,but a sudden stop or a fast
increase again,you feel the imbalance...The beads would be a + at the Bonneville salt flats
but not at differential speeds,..of course that was mine and the clubs opinion.
PS,.one member had a slow leak in his tires and was finally found that the problem was with these beads had found their way in the rims bead!
Old 10-06-2017, 07:19 PM
Bluesugar. Thanks for the info!! What your describing makes sense.
Most bikes and some of our cars can accelerate and decelerate very fast so what you describe may be reason to avoid.
Is it just HARD accel/decel that creates the issue or would it still be an issue even in something with slow accel/decel like an 18 wheeler?
Old 10-06-2017, 09:47 PM
72projectbird's Avatar
I use beads to balance the 37" MTRs on my F350. In fact, most guys running large tires use beads to balance.
They work OK. It would be easier to tell how well they actually balance if I was running a smoother tire.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-07-2017, 11:04 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
If the Normal balancing procedure is not fixing the problem, there could be:
An internal tire separation
Wheel incorrectly mounted on the balancer
Balancer needs calibration.
Wheel out of round
Stiff spot in tire causing a high road force number/variation.
Flat spot on tire from a panic stop.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 10-07-2017, 11:26 AM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
I have these in the rear tires of my 78 Cutlass race car, 27 X 10.5 - 15 Hoosier Quick Time Pro on 15 X 8 Weld Prostars. No vibrations.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 10-07-2017, 10:20 PM
I have he beads in my '62 Lincoln. The car has 20" rims with 40 profile tires. Dyna beads are not recommended as the sole balancing method for tires with that short of a sidewall. The tires are balanced OK, but still had some vibration. I left the wheel weights on and installed 5 oz of beads per tire. They call this a maintenance amount. They did take out most of the remaining vibration. I'm happy with the improvement they made.
1963 GTO project
Old 10-07-2017, 10:45 PM
lfdsteve's Avatar
Again, what makes the beads find the light or heavy spot? Answer, nothing. It just dosnt make sense that it would work. There is no correlation between annout of balance situation and beads!??
Old 10-07-2017, 11:44 PM
64speed's Avatar
64speed 64speed is offline
Unicorn magic LOL. No seriously I don’t get it either
Old 10-08-2017, 07:41 AM
I am not saying that they do or do not work well, but the theory of how they work is explained here:
http://www.innovativebalancing.com/HowItWorks.htm
Old 10-08-2017, 09:06 AM
lfdsteve's Avatar
Thanks. Now I know it's Bull dukey! Is this made by the same company that makes the "turbo" air cleaner intake inserts and the deal that gives you better gas millage when you wrap it around your fuel lines?
It seems to defy physics and logic?
Oh well, thanks for the link.
Old 10-08-2017, 11:36 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
I appreciate the diagram because it gives me a mental image of why it might work. It's not that that convinces me though. What convinces me is that they seemingly have fleet customers and people using them in the big off-road tyres. Strikes me that neither group would bother if it was all gimmick. Had never heard of this before.
I really liked the thing about off roaders telling them how to air down their beaded tyres safely without shooting their eyes out with ceramic bbs. Worth the read just for that.
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 10-08-2017, 02:53 PM
NeighborsComplaint's Avatar
Reminds me of the "Tire Balancing Rings" that were sold by Warshawsky & Co.. & JC Whitney Co. in Chicago. I believe JCW is still in business out in Kankakee, IL. Most of you guys are too young to remember this mega-parts catalog house (JCW was the mail order arm of the Warshawsky retail store located on South State Street in Chicago.
The rings were clear plastic tubing that contained steel ball bearings that were supposed to roll into place and effect a correct balance. They snapped onto the inside flange of the wheel much like a trim ring.
They were basically useless devices designed to separate the purchaser from his money.
It's amazing how someone who has never tried them is convinced they don't work.
1963 GTO project
Old 10-08-2017, 03:32 PM
lfdsteve's Avatar
Jon, it's not that they don't work. ITS THAT THEY CANT WORK!!!!
C'mon buddy, think... There just going to roll around!!!
But **** dude, go for it. I'll even sell ya a bunch I got laying around from my kids.
