Old 10-15-2017, 05:21 PM
dammen8's Avatar
dammen8 dammen8 is offline
Default Cylinder bore question with pictures
This is my number 4 cylinder... any idea what is going on? These marks are square with the bore, so it can't be water, you can definitely feel these marks.. the home was fresh at the beginning of this season. This is the only bore that did this.. thanks for any ideas.
Chad Dammen
ID:	465450   Click image for larger version
ID:	465451   Click image for larger version
3500lb 10.5" tire. [email protected] with a poor 60'
Old 10-15-2017, 09:12 PM
Are you running alcohol?
Have any head gasket problems?
Been out in the rain?
Old 10-15-2017, 09:25 PM
dammen8's Avatar
Vp x16 race fuel
No head gasket problems
No rain..
The marks are about 80% around the cylinder and square to the deck... if it was water the line would be at a angle to the deck... this is why I am confused...
Old 10-15-2017, 09:31 PM
slowbird's Avatar
slowbird slowbird is offline
Engine sit for a long time without being cranked over?
Old 10-16-2017, 12:27 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Ring faces look any different on that cylinder?
Old 10-16-2017, 06:14 AM
steve25 steve25 is online now
Is the block filled to passed that point on the wall?
All of those vertical marks are a sure sign that at least the ends of the oil ring rails need to be rounded over , a lot of fiction getting introduced there!
Old 10-16-2017, 06:34 AM
dammen8's Avatar
The longest the engine sat was 2-3 weeks if that.
Haven't pulled the pistons out yet.
The block is not filled, it's aftermarket.
Old 10-16-2017, 06:40 AM
dammen8's Avatar
The ring pack is total seal classic race
.043/.043/3mm the short block turned over at 11-12 ftlbs. Well according to the cheap craftsman beam style tq wrench.
Old 10-16-2017, 07:28 AM
What has made you yank the head(s)?
If that's where the piston in 4 was sitting when you pulled the head, then it sure looks like signs of water to me, but I woukd not expect such to be showing rust pitting around 360 degrees of the Bore , only on the low side of the piston if the motor was sitting in a normal position.
You could have a leaky valve seat coolant wise?
Looking at the first shot again I see what I believe is a crack in the wall below those pit marks and just to the right of that second gas port hole.
Old 10-16-2017, 07:52 AM
dammen8's Avatar
I put the heads on at the beginning of this season , they were used and needed the valve job touched up... I just didn't have time earlier to do it so I lapped the valves and ran it... also the connecting rods are only rated to 850 hp and I was way above that, so I was going to upgrade my rods as well...
I was questioning if that was a crack also.. might have to get the block pressure checked...
Old 10-16-2017, 07:59 AM
If the chamber and plug from 4 look cleaner then the others then chances are it's from water.
A crack my not open without heat, a Mag test is the way to go and far faster and cheaper!
Way above 850 hp by means of NA?
Old 10-16-2017, 08:14 AM
dammen8's Avatar
It made 870 n/a and I was spraying a .026 jet in a fogger.. so 225-240 ish...
Old 10-16-2017, 08:16 AM
dammen8's Avatar
All the chambers and pistons looked the same, nothing was steam cleaned...
Old 10-16-2017, 09:02 AM
Well at any rate that cylinder needs to be confirmed as good or bad at this point!
Old 10-16-2017, 09:29 AM
ponjohn's Avatar
ponjohn ponjohn is offline
If needed, can that one cylinder be sleeved?
Old 10-16-2017, 09:31 AM
dammen8's Avatar
Fully agree!
Old 10-16-2017, 11:49 AM
dammen8's Avatar
I would figure that would be the fix..
Old 10-16-2017, 12:56 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Is it a thin spot with coolant seeping in from the back side?
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 10-16-2017, 01:56 PM
Pressure check along with a good sono of area. A sleeve should take care of it.
Old 10-16-2017, 02:04 PM
mysticmissle's Avatar
total seal gapless? did it use any oil?
