Old 10-19-2017, 12:04 AM
torqhead's Avatar
torqhead torqhead is offline
Default Wiper - switch from low to high causes wiper motor to go in and out of park position
Weird problem. When I’m using my wipers if the wipers are already running in low speed and I turn the switch to high speed the wipers go in and out of park position real fast. If I turn the wipers off completely and then turn them on straight to high speed from park position the wipers run in high speed like normal. Basically it works properly then. Wondering what would cause this?
Old 10-19-2017, 01:42 PM
check the ground to the switch
Old 10-19-2017, 01:51 PM
torqhead's Avatar
Will do, thanks.
Old 11-13-2017, 11:19 PM
While checking grounds check the motor for a good ground.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
