Old 11-05-2017, 12:08 PM
kthelen's Avatar
kthelen kthelen is offline
Default 1971 vs 1972 - differences / changes
After a conversation with my old man (who owned a '71 and two '72s, along with lots of parts, and got me hooked on these cars in the first place!), I got to wondering - what differences do YOU use for identifying a car as a 1971 or 1972 at a glance?
Here are the ones I usually look for:
- Grilles. (Super easy one... '71 has less/larger vertical fins, and no horizontal bars)
- Woodgrain panel near passenger's knees. ('71 had silver block letters, all caps; '72 had gold script, mixed case, "cursive" letters)
- Speedometer. (120 MPH speedo w/ seatbelt nag light will be surely from a '72... but anybody know when, exactly, it started? Some say "all '72s", but I recall reading it was a mid-year thing)
- Taillight bars. (Not a super good indicator. I'm fairly sure the '71s didn't have them - but then, their absence may just be because someone forgot to put them back on!)
I'm guessing there could also be some number of paint colors that didn't cross over, though I've never dug that deep. I do recall reading in an old Chilton's manual that the 350 was no longer available in '72, nor was the 4-speed.
What other things can you think of?
Old 11-05-2017, 12:57 PM
1969GiPper 1969GiPper is offline
Didn’t know that the bars were removable. I thought that the bars were molded into the 72 taillamp lenses. The complete 72 lenses could be used on a 71 if you weren’t concerned about appearance. I believe that 70 models also had the bars while the 69 didn’t. Same interchangeability between 69 and 70 if appearance wasn’t important.
Old 11-05-2017, 02:10 PM
necdb3's Avatar
necdb3 necdb3 is offline
Tail lights had a silver surround in 72.
Old 11-05-2017, 08:03 PM
skullbucket's Avatar
skullbucket skullbucket is offline
My 72 was built in Oct of 71 and has the 140mph speedo, there was a mid year change to the 120 with the addition of a seat belt warning light.
Also the little tail light separators are removable on a 72 only held in place with longer screws.
Old 11-05-2017, 09:56 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
71 grilles are the first thing you see at a glance. Took me forever to find a set and had to settle with an eBay purchase with some dings but the 72 grilles (which were plenty) are just ugly!
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
Old 11-05-2017, 10:29 PM
Mapearso Mapearso is offline
different steering wheel ( i believe )
