Old 12-04-2017, 08:23 PM
Pearlbluebird's Avatar
Pearlbluebird Pearlbluebird is offline
Default Fold Down Rear Seat Install
Has anyone ever tried installing a 67 fold down seat in a 68 convertible? Other than changing the way it clips in on the top. Would it work?
A second class drive is better than a first class walk.
Old 12-05-2017, 09:01 AM
68tpls400 68tpls400 is offline
As long as you don't use the '68 latch, it will be fine. And you would need to use '67 upholstery as the '68's have the 'notch' for the latch. Everything else is pretty much the same.
Old 12-05-2017, 12:44 PM
I don't have the 2 holes drilled from the factory back there for the hinges. I do see 2 pockets in the area for location. Does someone have a picture or a measurement where to drill to mount these hinges?
Old 12-05-2017, 12:46 PM
I did pick up the 67 latches from Ames to hold the seat in place. thanks
Old 12-05-2017, 09:29 PM
Sorry, I don't have any pictures, but there is like a triple bend in the hinges, and they really lay and form against the seat pan quite nicely. When you play with that fit, you will discover there really is only one place they can go.
Check it out. I did one car with original hinges, and two others with repop hinges. The repops fit identically to the originals.
Old 12-05-2017, 11:48 PM
A Schab A Schab is offline
The hinges mount to a pair of weld in brackets that have a slot and a threaded stud.
