Old 12-18-2017, 09:41 AM
462 HO 462 HO is offline
Default poly lock rocker arm nuts
I think my crimp nuts are coming loose, as they have been backed off and retightened a few times in my attempts to properly lash the valves.
I am looking to get poly lock nuts for the 7/16 studs on my 455 HO.
Will I still be able to use the factory oil drippers, and if not, how important are they?
Also, Crower nuts are a lot lower price than Mr, Gasket, etc, ($38 vs $64).
Is there any reason not to use the Crower ones?
Thanks!
Old 12-18-2017, 10:32 AM
ponyakr's Avatar
ponyakr ponyakr is offline
"...Crower nuts are a lot lower price than Mr, Gasket, etc, ($38 vs $64).
Is there any reason not to use the Crower ones?..."
Haven't read any bad reviews of the cheap Chinese poly-locks. Back in the old days I used Mr. G. But nowadays, there are lots of brands cheaper than Mr. G.
CC has some cheap ones.
https://www.summitracing.com/parts/c...RoCOowQAvD_BwE
http://www.jegs.com/i/Comp-Cams/249/...RoC_OsQAvD_BwE
https://www.ebay.com/itm/COMP-CAMS-4...4383.l4275.c10
Old 12-18-2017, 11:16 AM
Great. I will get the cheaper ones.
Can the oil dripper rail be retained with poly lock nuts?
Old 12-18-2017, 11:37 AM
Formulajones's Avatar
I've used oil drippers before with poly locks. Usually I double gasket the valve covers for clearance.
Oil drippers aren't really a necessity anyway. GM went away with those on most engines in late 60's and early 70's, not to mention most people back then were hotrodding with aftermarket covers, and none of those have drippers either.
I have several examples here running without the drippers for many years using full roller setups and ball/socket setups. So if you feel the need to remove them, it's not an issue.
Old 12-18-2017, 02:16 PM
gtospieg gtospieg is offline
you will probably have to bend them flatter so they don't hit the taller poly locks...I did
Old 12-18-2017, 02:19 PM
Joe's Garage Joe's Garage is offline
Default Or space them up using thick washer's on the attaching studs
I've done that a couple times to get extra clearance.
Old 12-19-2017, 03:12 PM
GRX's Avatar
GRX GRX is offline
Poly locks are always good.
Yeah. Crimp nuts are only made to be used once. You can go the cheap route and re-crimp them by crushing in a vise, or smacking them with hammer on anvil. Not fancy but it works.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 12-19-2017, 05:31 PM
dataway's Avatar
dataway dataway is offline
The crimp nuts are so cheap that I typically just buy a new set if I have to do much adjusting.
