Old 12-19-2017, 07:48 PM
TB1's Avatar
TB1 TB1 is offline
Default differential parts interchangability
I'm trying to find out for sure if a open carrier and gear set from a 1969 Grand Prix would fit into a 1965 Lemans, IE are they both 8.2 " ring gear and 28 spline axles. Yukon gear and Richmond gear seem to show them being the same part numbers for parts but that doesn't mean its always correct. just wanting to make sure before I buy another possible boat anchor...
Trevor
Old 12-20-2017, 05:56 AM
Kenth's Avatar
Kenth Kenth is offline
Welcome to the Forums!
Moving the carrier and gears in those rear ends will work just fine.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 12-20-2017, 07:12 AM
steve25 steve25 is offline
Yes, they bolt right in, but getting the ware pattern to match up again a have a quite rear is gonna take some time my friend!
Old 12-20-2017, 10:21 AM
TB1's Avatar
TB1 TB1 is offline
Perfect thanks for the confirmation, hopefully it will go together and runs ok only reason I'm going this route is that I bought a Powertrax no slip locker all ready but it didn't fit with my current carrier as the stock cross pin was .7325" and the powertrax was.800" which they assure me is correct for a Pontiac 8.2 carrier so I'm not sure what the deal is with the what I thought was Stock 65 rear in my car
Old 12-20-2017, 11:40 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
http://forum.jdrace.com/viewforum.ph...c210ee222ddbfb Alot of good info on here about the 8.2s. 68 thru 70 buick had larger carrier bearing on drivers side than on the other side. Be aware some of the pontiacs were fitted with this buick rear instead of the pontiac one. My car was like this when it had the original 8.2 in it with one rib on the side of differential for buick instead of two ribs for pontiac on 8.2.
Old 12-20-2017, 04:45 PM
pontorquer's Avatar
pontorquer pontorquer is offline
You may want to contact 'ol Pinion head member as well, he knows a lot about Pontiac rear ends ...
Old 12-21-2017, 10:18 PM
pontorquer's Avatar
I'm pretty sure 1964-70 8.2 BOP carrier are all the same, someone correct me if I'm wrong ...
Old 12-21-2017, 10:25 PM
TB1's Avatar
TB1 TB1 is offline
From what I can tell yes they are, just wanted to verify for sure. Still want the one we talked about for sure just didn't need another paper weight in the Garage.
Old 12-22-2017, 09:09 AM
The early 8.2 bolt-in axle open carriers took the smaller diam cross shaft for the spider gears. Was at least a '64 thing, if not all of '65. The open carrier used in Pontiac 8.2 rears directly after that style, up through '69 models took the rh thread ring gear bolts & had the larger diam cross shaft.
The majority of 3.23 ratio '69 GP rears I've had over the years have been 4 pinion Safe-T-Track rears. I have yet to run across a factory '69 Pontiac A-body or GrandPrix rear that took tapered bearing axles, & the '70-72 style carrier & ring gear with larger diam LH thread ring gear bolts. From what I've come across so far, & have torn down tons of '69 Pontiac 8.2 rears, the tapered bearing axles & larger diam ring gear bolts/carrier first appeared in late '69 Firebird rears.
Old 12-22-2017, 09:13 AM
No,
also "8.2 BOP" is not what was built, that is just a really poor name that has been thrown about by the aftermarket parts mfg's for over 4 decades.
Old 12-22-2017, 09:22 AM
TB1's Avatar
TB1 TB1 is offline
Thank you for the info. That explains the cross shaft issue I had as my 65 I from what I can tell still all original part number on the diff indicated 65. I’m the third owner and it’s a 6 cylinder so not like the car was beat on and parts changed all over the place.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
