Old 01-16-2018, 02:33 PM
Old Goat Racer's Avatar
Default 1 7/8" OR 2" Headers
On a 550 HP motor how much will the HP increase with 2" headers ?
ET gain ? Currently using Doug's .
Anybody with experience ?
Everybody knows somthin.
Nobody knows everything !
Old 01-16-2018, 02:58 PM
grandville455's Avatar
grandville455 grandville455 is offline
I used 1 7/8 on my pump gas 468 and made 651hp
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 01-16-2018, 03:04 PM
GTOGEORGE's Avatar
Remember a Racer is alway stepping up, so BIGGER is better.
GTO George
Old 01-16-2018, 04:03 PM
BADDTA's Avatar
BADDTA BADDTA is offline
We use 2” maddog headers on our 434 that made 705 hp with the heads we bought from you. 😉
Brian
Boobs & bacon
Old 01-16-2018, 04:52 PM
Hooter's Avatar
Hooter Hooter is offline
Not a comparison, but my pump gas motor made 820 with 2" and the crap/flat collector design Heddmans.
67 Bonneville ragtop
Old 01-16-2018, 08:52 PM
scott70's Avatar
scott70 scott70 is offline
i had dougs 1 7/8" on my 455 thats dynoed 625. Ran it at the strip and then tried hooker 2" and gained nothing in ET. The dougs fit better and easier to put the header bolts in and tighten. Dont waste your $ and time going to 2" on a 550hp motor.Id be curious if you would loose any power with 1 3/4".
Old 01-16-2018, 09:21 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Depends on the rest of the system also. If the mufflers/tail pipes are to restrictive the larger header won't help at all. But I agree with Scott70...1-7/8" are most likely all you need.
Old 01-16-2018, 10:14 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
It does depend on the exhaust system and also the exhaust port. Going to big slows velocity scavenging out of the port too. Low velocity and a port that flows backward well you can get some reversion.
Skip Fix
Old 01-17-2018, 07:25 AM
steve25 steve25 is offline
Some info for thought.
Old 01-17-2018, 07:58 AM
taff2's Avatar
taff2 taff2 is offline
2" headers woke up my old 400 n/a combo over the previous 1 5/8", race use, 575 hp at 7000rpm.
Old 01-17-2018, 08:44 AM
Not surprised, as that size tubes are only good for 350 cid & under motors and from what I have seen the 2 inchers you have are a tad too big for a 400 at that level of power .
Your tossing away some average hp and TQ numbers with those 2 inch tubes!
Are you talking about 2" id, or od,
Old 01-17-2018, 08:56 AM
ta man ta man is offline
FWIW I run 126mph with 1 3/4 Hookers.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 01-17-2018, 10:06 AM
Skip Fix's Avatar
My RAIV 400 400 hp liked 1 3/4 over 2" with a muffler system(2 chamber 3" Flowmasters. It had reversion issues with 2"
Pretty sure JB Clegg's 455 SD Super Stocker has Doug's 1 7/8s. Lots of Engine Masters and Sprint cars use 1 7/8 and making 600 HP.
Skip Fix
Old 01-17-2018, 10:45 AM
Steve C. Steve C. is offline
That formula posted above was published by David Vizard. As many know much of his work has been centered around Chevy engines, especially the 350cid. Therefore I've often wondered if it might be canted in that direction.
That said I've taken note of it and worked the formula around my Edelbrock heads and with porting the exhaust port ended up towards 250 cfm at the upper lifts. As noted David's formula is based on the INSIDE diameter. I run 2-inch headers (outside diameter) on my 505 that makes peak power at 6000 rpm.
Here is another one below that tends to back that up.
How Header Primary-Tube Diameter Affects Performance ?
Tech article from Hot Rod magazine:
http://www.hotrod.com/articles/heade...s-performance/
Old information here:
Old 01-17-2018, 01:37 PM
Don 79 TA Don 79 TA is offline
This is right on topic as i have thought about this very thing
d-523 on their websites states 2" ID
i'm thinking about replacing the round port 1 7/8 with the 2"
not sure if i will have an oil filter access issue or z bar issue
but i can say the current headers were a dream to install, so easy
WAY easier then the D's i had at one time
Old 01-17-2018, 01:42 PM
Skip Fix's Avatar
Don 79 TA, my Hooker Super Comp 4202 round port 2" good oil filter access and fairly easy to install. Tight on the bolt behind #5-made a special bent wrench. I think Larry Navarro had a set on one of his round port stick cars so should be OK for fit there also. Never had the Hedman 2" for round port so not sure their fit.
Skip Fix
Old 01-17-2018, 02:44 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
My d port headers I built use the hedman adapter plates, have 1 7/8 primary than stepped to 2" od than 3.5 collectors , I didn't think a full 2 was needed, about 550 hp, now with new heads should pick up another 100 hp and leaving them alone. . Header design especially equal length tubes play a big part
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 01-17-2018, 07:22 PM
taff2's Avatar
2" od, so probably 1 -7/8" id. I believe I got the dimensions from the old Pipemax program/calculator. I ran 9.61@137mph consistently with that combo at around 2800lbs IIRC.
Old 01-18-2018, 01:46 PM
thanks
i know my friend had issues with headmans back in the day, not sure if they changed/improved
if i go with the larger Dougs headers i am hoping it fits up to the exhaust otherwise not really interested
i know the D header swap to the round port Dougs did connect just fine
