Old 01-24-2018, 10:47 PM
skullbucket's Avatar
skullbucket skullbucket is offline
Default Intake swap
I figured I would wake this forum up a bit.
My GP has a cast iron 72 Intake with a 1 inch adapter to use a 750 Holley Square bore on a quadrajet intake.
It runs very good like this but I know "carb to intake" is more right.
So I research for 2 days but know what I want but "search" is fun soooo.......
Anyway Performer or RPM??????? According to "YOUTUBE the Performer has small runners and a factory cast intake is better.
A RPM sits high and adapting linkage and air cleaners is a PITA but I beleive I'll survive.
So as of now im waiting for probably 2 days for the RPM and maybe Thursday I'll start to drain the rad and other misc stuff .
1972 Grand Prix
Old 01-25-2018, 09:09 AM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
i was wondering which type of adapter your using. the one I had, placed the primaries right over the divider of the intake, between the primary and secondary. then I saw one that the primaries were tapered to the primary hole and missed the divider all together.
Old 01-25-2018, 11:56 AM
It’s the one you use to adapt the square bore to a spreadbore intake or flip it over and adapts a quadrajet to a square bore intake.
1972 Grand Prix
Old 01-25-2018, 08:18 PM
that's the same one I started with. looked like this:
https://www.summitracing.com/parts/sum-g1401/overview/
I'd like to modify a stock intake to look like a performer and use this adapter (modified to mirror the intake opening on one side and blended up to the holley flange on the other) I think I wouldn't hinder performance at all and not be as tall, for better hood clearance.
https://www.summitracing.com/parts/edl-2696/overview/
from you other thread in the street section. this is the sealing plate I mentioned.
https://www.summitracing.com/parts/edl-2732/overview/
don't know how truly necessary it really is, but with how close the square flange seal of the carb is to the spread bore flange of the intake, I did it for that warm fuzzy.
as far as performer or rpm. definitely rpm. I don't think it loses enough, if any, on a stock engine to really matter and leaves plenty of room for future growth if desired.
Old 01-25-2018, 09:04 PM
Yes the flat, thin adapter/spacer is necessary or the carb base will leak on the RPM with a square bore Holley.
Im more of an aftermarket parts guy so sooner or later it would have got an aluminum intake anyway, valve covers are next, then some sort of cylinder head swap/work.
1972 Grand Prix
Old 01-25-2018, 09:42 PM
Lee's Avatar
Lee Lee is offline
On a mild 455 that I built in the early 90's, highway gears, shifting at 4600 - I ran 13.2's with an iron non-EGR intake, and a few hundredths (as in 0.0x seconds) slower with the Performer - no other changes. IMHO, the two intakes perform virtually identically.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 01-25-2018, 11:48 PM
I like the stock stuff and the aftermarket stuff. my current '70 with a 455 is topped with alum. kre d ports, torker II, 750dp, and some hooker headers.
Old 01-26-2018, 03:38 AM
Yes with 400 to 455ci it doesn't take too many parts to make a nice quick car, I like my basic bolt ons then some cylinder heads or mild home port work .
Love my aluminum intakes and Holley carbs best!
1972 Grand Prix
Old 01-26-2018, 11:24 PM
Summit has super quick shipping!
1972 Grand Prix
Old 01-27-2018, 01:45 AM
Sprocket's Avatar
Sprocket Sprocket is offline
Ooh yeah! It is not a pain in the ass to install. Your Holley will be much happier now.
'70 GP Model J
467 Butler ported Edelbrock D-ports
Torker II intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers full 3" stainless exhaust
TH400, 3.50 9" CurrieTrac, 245/35-20 Front, 275/35-20 Rear
