Old 01-29-2018, 05:26 PM
bober bober is offline
Default what are the reviews here on DUI dist . ?
Are these reliable ?
Old 01-29-2018, 05:58 PM
Chris65LeMans's Avatar
Thumbs up from me. I haven’t heard anything bad about them, and love mine.
Old 01-29-2018, 07:25 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Thumbs up DUI
Thumbs up here too. Good quality and setup my cars
Specs.
Running one for several years.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 01-29-2018, 07:30 PM
PDC PDC is offline
Default Thumbs Up!
I’ve got a pair in use for several years and several thousand miles of perfect, worry free service. The curve you order is dialed in on a Sun machine and both of mine are spot on.
Old 01-29-2018, 09:30 PM
Great news !!! I have one located at a good price but just thought I'd check !! Thanks ALL !!
Old 01-30-2018, 10:46 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
One in my 78 for over 20 years, have one in the 500" IA motor also.
Skip Fix
Old 01-30-2018, 11:07 PM
pontiacpetey's Avatar
pontiacpetey pontiacpetey is offline
Thumbs up, great customer service. I didn't get any crazy hp increases but overall drivability is much improved . Through all my rpm range it's solid. Also a definite increase in idle quality. No more struggling to run while the engine is cold.
Many men go fishing all of their lives without knowing that it is not fish they are after. ~Henry David Thoreau
Old 01-31-2018, 12:34 PM
track73 track73 is offline
I didn't use their distributor but I did use their module, coil, cap and rotor in my Mid American stock car. It won many races and a track championship. It never missed a beat. I ran .050 spark plug gap. Peak rpm was about 7200.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 02-02-2018, 06:41 PM
Thanks everyone for your input . I have purchased it and it should be set to work on my 455 according to the DUI folks . It's marked on dist 22* @ 3000 rpm and has a vac advance .
Old 02-02-2018, 06:49 PM
Skip Fix's Avatar
Mine dynoed the same as a MSD and 700 box on the dyno.
Skip Fix
