Rear sway bar bushings
Was doing some research on PY and the net for rear sway bar parts and came across a reproduction bushing being made by our friends over at NastyZ28. These are a match for the 5/8 bar, lower bushing Part #3983071
Contact is Thomas Gerard <akron70rs@yahoo.com>
1970 RAIII white/blue |
Saving this
http://www.fquick.com/garages/viewga...ewimg&id=74990 "You people have stood in my way long enough. I'm going to clown college." -Homer Simpson |
Thanks RamAirpwr! What are they charging for a set?
1970 T/A |
What are they made from? Hopefully OEM type rubber?
...Steve T. "Resurrection of a 1970 Trans Am" Blog www.455hota.wordpress.com ------------------------------------- 1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior) 1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior) |
I have a bunch of NOS bushings, and they all seem to have a flat area? Is that the correct shape?
Mike/Illinois |
The bushings that are on the ends of the bar would have flats. The bushings that go where the links are would be round.
Do the link bushings look like that?
Mike/Illinois |
Yes, the link has the Permanent bushing in the top and that bushing on the bottom. There is a different bushing for each size sway bar.
Good to know! Repops are a lot different then.
Mike/Illinois |
Unless I am missing something, I believe you may be mistaken;
It sounds like sway bar bushings you mentioned which do have a flat, are for the ends, not the links - these are for the links. It sounds like you're talking about part #7, but this is the bushing for the link - which isn't actually shown in this diagram, but is sandwiched in between the link (#1), and the link cap (#9). It is worth noting that the sway bar end links did change; I am unsure if the revised links used a flat on the top. As Norwood mentioned, there is a different bushing for each sway bar size. I actually started following this thread yesterday, because up until now, I was unaware of a bushing made for this - I had understood that most people just made one out of rad hose...
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 02-13-2018 at 12:23 PM. |
Your Trans Am should have a 7/8" (0.875") rear bar;
This is for a Formula, which came with a 5/8" (0.625") rear bar. @ RamAirPwr; Again, do you know what is being asked for a set?
here is a link for a reproduction rear sway bar end link - which clearly shows the rounded shape on both ends:
https://www.camarocentral.com/1970_1..._p/sus-903.htm Here are two different sizes that I found from the same vendor: https://www.camarocentral.com/1970_1...p/sus-908a.htm https://www.camarocentral.com/1970_1..._p/sus-908.htm
Here is a good pic I just stole from Bruce. It shows the round bushing and the one with the flat that is on the sway bar end under the spring plate
well bummer.
It looks like this thread might have been all for nothing. I emailed Tom, and got this reply: Quote:
I am sorry but I only have the 11/16 and 9/16 diameter at this time. What demand do you anticipate for the 5/8 inch bushing? It could be produced in the future if there is a big enough need. Thanks for you interest. Tom I'm gonna take a leap of faith and say the 9/16 will be interchangeable with the 5/8 (formula) and the 11/16 with the 7/8 (T/A) What do you guys think? $40 pair shipped Quote:
Formula 5/8 bar Image #7 GM Part #480912 or Energy Suspension Part #9.5104G Image #1 GM Part #3982298 (link w/bushing) For the bushing only, use Energy Suspension Part # 9.8140G (this is the bushing on the top of the link) Image #9 GM Part #3983071 or repop from Tom T/A 7/8 bar Image #7 GM Part #482333 Image #1 GM Part #3982298 (link w/bushing) Don't have a cross reference for Energy Suspension Image #9 GM Part # 3986486 or repop from Tom Hope this helps!
I bought my lower drop link replacement bushings for my small diameter rear sway bar from PST (performance suspension technology).
They are not made from OEM rubber, and have a little larger diameter on the outer edges. You can see that in the pic I attached. I figured this was the best I could find so that is what was installed. These were much better than my originals: Sent from my iPhone using Tapatalk
The Following User Says Thank You to 455hota For This Useful Post: | ||
(Jonny, BTW many '70 T/As came from the factory with a 5/8" rear bar, even though the literature said they should be 7/8").
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
/\ yeah, I have read that.
It seems to me that often owners look to correct factory mistakes - which played into my reply. I told him that if he did a run, I'd buy two sets as well. I also encouraged him to check out this discussion.
If we are looking for potential buyers of the correct bushing for the 5/8 bar, I will buy a set.
Ill buy a couple sets
