Old 02-18-2018, 09:44 PM
billkinney billkinney is offline
Default new motor
I need to rebuild a 400. heads are 6x 100cc with some flow work ,a street comp cam , performer intake w/ 1460 edelbrock and a spun rod bearing. What pistons and rods do you think I need to make a nice tire smoker?
Old 02-18-2018, 11:11 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
RPM rods and Speed Pro L2262F for a low cost build. Might need to mill the heads some...
If your crank needs work you might want to look at something like this...
https://butlerperformance.com/i-2445...tegory:1234863
Old 02-18-2018, 11:35 PM
STEELCITYFIREBIRD's Avatar
https://www.summitracing.com/parts/s...SABEgLONvD_BwE
This
Old 02-19-2018, 12:23 AM
ponyakr's Avatar
ponyakr ponyakr is offline
Hey, if you can drive over to North Central Louisiana, to pick it up, I've got a 455 short block that will make lots of tire smoke, using your heads, intake, carb & cam.
Price: $2000. OR, $2800 with my 6x-8 heads, which have stainless valves. Also includes FlowKooler alum water pump, CC 1.52 roller tip rockers, poly locks, tall chrome covers with K&N breathers, factory HEI with DUI cap/coil/rotor, MSD rev limiter module, & Summit mini starter.
500813 block, factory 455 crank, forged rods & pistons, CC 292 Magnum cam, Rhoads RL9518 lifters. Less than 2 street miles, and no track time.
Built by a long time racer and member here. If interested, you can Email me at: [email protected]
ID:	475965   Click image for larger version
Old 02-19-2018, 12:51 AM
Tim Corcoran's Avatar
Your compression will be a little low with 6X heads on a 400. You might consider putting a stroker crank with a 4.21 stroke that would get you in the 9.0 to 9.5 range depending on the bore size you plane to go with. That extra compression will wake it up not to mention the extra cubes you will gain. Butler Performance has a stroker rotating assembly that should do fine for you.
This is what you need, they may have a more economical 4.21 stroker kit with different pistons and rods
Tim Corcoran
Old 02-19-2018, 12:58 AM
ponyakr's Avatar
If you have a 557 block, a stroker assembly might not be a good idea.
Old 02-19-2018, 07:06 AM
Cliff R's Avatar
Cliff R Cliff R is offline
6X-8 heads just don't make much compression in a 400 build. Better off to source out some heads with much smaller chambers, or go the stroker route as mentioned.....IMHO....
Old 02-19-2018, 07:30 AM
steve25 steve25 is offline
If your heads are already fully rebuilt then I would Mill them .045" on the deck and Intake flange and then in the rebuilding process of the the block deck it to achieve +.005" on the piston to deck height .
To me stroking a motor is waste with lightly ported heads unless very soon down the road you will be swapping on aftermarket heads or well ported iron heads!
Old 02-19-2018, 08:35 AM
ponchjoe's Avatar
Originally Posted by STEELCITYFIREBIRD View Post
Not sure how a line lock will help LoL
Old 02-19-2018, 10:17 AM
poncho447's Avatar
poncho447 poncho447 is online now
Well, he did say he wanted a nice tire smoker. A line lock would do it
Old 02-19-2018, 10:28 AM
Oh, I thought he was talking about a new 8 hour BBQ technique!
Old 02-19-2018, 10:29 AM
ponyakr's Avatar
"...To me stroking a motor is waste with lightly ported heads..."
"...to make a nice tire smoker..."
A stroker, with completely unported iron heads, should produce near 400hp/500 torque, which should "...make a nice tire smoker..."
He doesn't need max high rpm hp, leaving nothing "on the table", in order to make plenty of low rpm, tire smokin, street power, IMO.
Contrary to popular belief, not everybody needs 500-600hp in their mild street tire smoker.
Old 02-19-2018, 10:45 AM
ponchjoe's Avatar
I saw his other thread about the issue with his 400 mile warrantied rebuild. He needs to go fight for that so this build may not happen if he asserts himself into fighting his builders rediculous claim to get out of the warranty....
http://forums.maxperformanceinc.com/...d.php?t=815150
Old 02-24-2018, 11:03 AM
The heads were cut .45 and the intake was matched. Stroker sounds good to me. As far as the previous motor I don't think I can trust that it'll last. I'd rather have the money to build another myself.
Thanks for all your inputs.
Old 02-24-2018, 12:11 PM
leeklm's Avatar
leeklm leeklm is offline
"Contrary to popular belief, not everybody needs 500-600hp in their mild street tire smoker."
Now that is pure blasphemy!
True statement, but 600hp in a street tire smoker sure is fun!
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
