Old 02-27-2018, 08:46 AM
hotcharity95's Avatar
hotcharity95 hotcharity95 is offline
Default attach window molding
what would be the best way to attach this window molding? it's for a convertible between the front and back windows, attached to the back window.
Old 02-27-2018, 09:07 AM
Greybeard421 Greybeard421 is offline
I use dum-dum. Works well. Or you can also use a small bead of urethane.
Old 02-27-2018, 09:41 AM
gto4evr gto4evr is offline
as stated, you can just silicone them on but the proper way is by pressing them on with new rubber inserts if the old ones are junk. Are the old inserts still inside the sash channel? it's a rubber C shaped piece that goes over the edge of the glass then the sash channel is press fit over it. (remove the rubber seal off the front first then tap it on to the glass over the rubber C channel with a rubber mallet)
Here's a link on ebay but I'm guessing Ames sells them too.
https://www.ebay.com/itm/Quarter-Win...9UIzaC&vxp=mtr
