Old 03-04-2018, 03:16 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Default The “Weight” Has Begun
Thought I would post this thread on my efforts to take the cursed bow out of my Formula hood. I meant to do this back in November after MCACN but just kept putting it off. Finally got around to it last weekend and plan to leave the weight in place during all the down time between this year’s events and cruise nights. I figure it should be better by the time I take it to Pontiacs in Pigeon Forge and the TA Nats this summer.
So, to start, here are some photos of the gaps on both sides and between the front of the hood and the header panel. The gap on the passenger side is the worst. The top of the hood is 9/16” higher than the top of the fender.
On the driver side, the top of the hood is 3/8” above the top of the fender.
At the header panel, the gap is 1/4”
I decided to leave the hood attached on the hinges to support the rear of the hood. I placed some lumber across the top of the core support and braced it so that the hood can rest on it and be supported at the front. The hood is free to move forward as it flattens out.
Next, I purchased six bags of all purpose sand,each weighing 42 pounds.
After covering the hood with a couple cotton bed sheets and a moving pad blanket, I placed the bags of sand on the hood as shown.
Check out the arch in the edges of this hood!
With the a total of 252 pounds of sand on it, I’m hoping it will start moving back to where it began. I plan to monitor it over the next couple months and add weight if needed; may even crank it a couple times each week and let the engine warm up to give it some heat to enhance the process
So, let the “Weighting” begin!
BJ
Sent from my iPad using Tapatalk
Old 03-04-2018, 04:08 PM
Pepi's Avatar
Pepi Pepi is offline
Interested to see how well that works and how long it takes. I should do that to mine of of these years.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 03-05-2018, 06:16 AM
Aus78Formula Aus78Formula is offline
Is the steel reinforced inner strips that the hinges bolt to removable? No doubt they also gain a bow over the years to match, pulling down on the front of the hood to close only makes it worse.
Old 03-05-2018, 07:37 AM
njsteve's Avatar
njsteve njsteve is offline
They are riveted to the underside. One side on my Gramma car's hood has a crease/inverted buckle in it from the bend. Or maybe it is the cause of the bow itself? When the metal bar buckles and bends it pulls the hood with it. I guess some of these hoods needs the rivets removed and the bar flattened or maybe turned over and re-riveted back on.
Old 03-05-2018, 09:22 AM
Judge273's Avatar
Judge273 Judge273 is offline
Did you measure the before you added weight in blocked position and after weight added to see if the weight actually changed the hood bow?
Mike/Illinois
Old 03-05-2018, 09:53 AM
The Boss's Avatar
The Boss The Boss is offline
Weighting...
And go racin' in the street.
Old 03-05-2018, 11:24 AM
Red Goat's Avatar
Red Goat Red Goat is offline
Well documented research there, BJ. Hopefully it will provide a long term fix.
Cheers,
Tim
Old 03-05-2018, 12:20 PM
OVERULD's Avatar
Mike, I did get the before measurements but forgot to check them after adding the weight. I had to be somewhere and was out of time. I'll check it today and compare. I didn't get the sense that the hood moved much at all. I also wonder how much weight the thing can hold without damaging it.
BJ
Old 03-05-2018, 12:35 PM
Judge273's Avatar
Thanks, don't push the limit...Looks too nice!
Mike/Illinois
Old 03-05-2018, 12:58 PM
vidguy's Avatar
vidguy vidguy is offline
I've done something similar with two 50 pound canvas Light Stand Sandbags (Video Studio) on the car cover, I' also leave the hood unlatched.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 03-05-2018, 01:06 PM
Good luck but that kind of stuff never seems to work for me... This bumper didn't even budge...
Old 03-05-2018, 01:35 PM
vidguy's Avatar
HA!
James
Work
Details here:
Old 03-05-2018, 09:27 PM
Judge273's Avatar
Wouldn't recommend that method on a hood...
Mike/Illinois
Old 03-06-2018, 12:26 AM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default Metal strips
On my first 74 formula i replaced the strips with thicker metal.
Old 03-06-2018, 01:04 AM
X2 I don't have one so can't see the issue first hand but can't see the hood wanting to change shape from where it was already pulled to over 45 years. If, however, the steel frame can be removed safely and straightened or even beefed up then it will hold the shape automatically. Even if made a touch too straight, the bumpers along the fenders will hold the hood at suitable height and nose of hood pulls down to wherever the catch is holding it. You can add shims and washers under the catch to pull hood front down more, not as simple to lift it at that point, only the corners.
Old 03-06-2018, 01:39 PM
SD455DJ SD455DJ is offline
B.J. - That looks like it should do the trick. I want to see how this ends up too, as I have a little bow starting and want to nip it in the bud.
Dennis
Old 04-28-2018, 06:42 PM
pjhconst pjhconst is offline
Default Formula Hood
Hello BJ just wondering how the Hood project is doing? Any improvement with the gap yet.
Pat
Old 04-28-2018, 11:43 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Just saw this post. Wish you a lot of luck BJ. I tried the something very similar on a trunk lid a while back. Left it for 8 months before getting the car ready for paint. It got about a 1/16" better, wasn't worth the effort. Maybe you'll have better luck.
Old 04-29-2018, 08:23 PM
OVERULD's Avatar
Hey guys, thanks for checking in. I have not touched the car since posting this thread other than to periodically check to be sure nothing was amiss. It has been two months now and the old Mark One Eyeball says nothing has moved. I will check it this coming weekend and maybe grab some more pictures. I have a few things that I need to get done on the car before making the trip to Pontiacs at Pigeon Forge in June, so it is time to get the cover off and get busy.
Thanks,
BJ
Old 05-03-2018, 10:21 AM
bird72's Avatar
bird72 bird72 is offline
"The Weight", a good one........ good luck & this will be interesting
https://www.youtube.com/watch?v=sjCw3-YTffo
also, I can't help but wonder if somehow heat could be used as part of process (w hood removal of course)
72 Bird
