Old 03-04-2018, 10:10 PM
wh33lman's Avatar
wh33lman wh33lman is offline
Default In-Tank EFI Fuel pump options for stock tank.
Sending unit and fuel intake are co-located in the same opening in a stock ('81) F-Body fuel tanks.
Is there an in-tank fuel pump for EFI that has a provision for the fuel gauge sending unit?
Old 03-05-2018, 12:21 AM
Tom Vaught's Avatar
Boost Engineer
http://www.tanksinc.com/index.cfm/pa...cat/cat128.htm
Part Number TM-201T fits 79-81 with Fuel Injection. It has a provision for EFI pump and their Fuel Sending unit, not the factory one.
Factory type tanl but not sure if EFI Pump fits.
http://www.tanksinc.com/index.cfm/pa...rod/prd283.htm
Tom V.
Old 03-05-2018, 02:39 AM
Squidward's Avatar
I've looked for some stuff like that, but ended up going with an in-tank pump that will leave the stock sending unit in place. I suppose there are late model OEM combo pump/gauge sender units out there, but I don't have the time to see what fits my individual tank. The one I went with will fit my 67 FB tank, and will work with FiTech's PWM. It adjusts to tank depth, but will still require a stock gauge sender.
http://fitechefi.com/products/40015/
Not totally what you are looking for, but I am not seeing a drop in pump/sending unit. I, like you, would have loved to see a singular drop-in unit. Drop in universal pump/float combo for GM cars, adjustable for tank depth... I see a market opportunity.
Old 03-05-2018, 08:37 AM
Lee's Avatar
Lee Lee is offline
Holley has a new product that is supposed to do just as you ask. I believe it is self-regulated, however, so you will not have a return line - that makes the install a bit simpler, but also makes it more susceptible to vapor lock.
Personally, I feel the TanksInc system that Tom mentions is the best current option.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 03-05-2018, 11:38 AM
wh33lman's Avatar
Yes that is exactly what I was looking for, but could not find anywhere.
Tanks INC has an EFI retrofit pump , but it has no sending unit.
The FiTech unit has a built in regulator, so the FiTech EFI's internal regulator is removed. Not sure if that can be done on the Sniper.
I looked at the new Tanks..and they do have the advantage of better baffling...but I was hoping to retain my stock tank.
So, you must have had to cut a new hole in the stock tank for the pump, right?
If so, how did that go?
Old 03-05-2018, 12:16 PM
wh33lman's Avatar
Good call !!
Holley 255lph OEM Style InTank Kit.
Old 03-05-2018, 05:35 PM
Tom Vaught's Avatar
Boost Engineer
I see their module does have the gas tank gage sender as part of the assy.
Tom V.
Old 03-05-2018, 06:11 PM
78w72 78w72 is offline
spectra also makes an intank pump/sender module that installs in the stock opening. they also make a complete tank/pump assembly with a baffled tank for a very good price.
http://www.spectrapremium.com/produc...ssemblies.html
the holley unit is the same type of pump/sender in one module that installs in the stock opening, it comes with their hydro-mat product. the holley is a non-return internal bypass design & they claim it helps prevent or eliminates vapor lock.
aeromotive also offers a drop in pump unit but requires cutting the tank & retaining the stock sender, they offer standard return systems & a non return internal bypass also.
Old 03-05-2018, 06:40 PM
73ta's Avatar
73ta 73ta is offline
I made my own with a Walbro pump. Pump with sending unit all together that fits thru stock hole into stock tank. No internal baffles in the tank so have to keep it above 1/2 for spirited driving. Thinking of adding a Holley fuel mat to it like the Holley referenced above.
Old 03-05-2018, 07:18 PM
wh33lman's Avatar
I would prefer 340lph for my setup, and do not mind drilling new hole in tank...but would prefer to not have an internal requlator.
Old 03-05-2018, 08:07 PM
aeromotive offers the bigger 340lph pump & the normal full return system is standard & uses a external regulator. they offer an internal bypass one for dead head carb setups but you still need an external regulator to dial down to what your carbs needs.
Old 03-07-2018, 12:04 AM
TransAm400 TransAm400 is offline
I have a brand new tank with the Aeromotive pump already installed. Have an ad in the classifieds. Send me a pm if you are interested.
http://forums.maxperformanceinc.com/...26tid%3D812462
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 03-12-2018, 05:32 PM
73ta's Avatar
Might as well go with Walbro's latest, I think it's a 450. Only one that is E85 approved. http://walbrofuelpumps.com/walbro-f9...-fuel-pump-e85
Old 03-13-2018, 03:29 PM
wh33lman's Avatar
I was leaning towards the Tanks Inc. intank pump with the attached baffle. Seems there's a lot of concern about fuel starvation when using an unbaffled tank. Their PA6 pump (Walbro) fits the bill.
However, fixing my stuck choke on the Q-jet, just unleashed enough power to immediately upset my tranny. So the EFI is on hold.
