Old 03-08-2018, 08:53 PM
84TA400 84TA400 is offline
Default 10.00 HP
How much HP is needed to go 9.90-10.10 in a race weight 2850lb car. Building a new power plant and trying to come up with the right combo. Thanks
1984 TA, 400 PONTIAC, th-400, 4.10 12 bolt
10.49@ 127mph 1.40 60'
R/U Pontiacs in the Park 2006(SAT)
R/U Pontiacs in the Park 2007(SUN)
Old 03-08-2018, 09:09 PM
3fastgtos 3fastgtos is offline
600 near sea level.
Old 03-08-2018, 09:32 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Won't take much to do it there are literally tons of ways to get there. Good stock block...4 bolt mains with good caps and lifter braces...decent set of heads,a solid roller cam with stud girdles and your pretty much there. A good 5k+ converter and your runnin 9's all day long
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.854@160.12 in Brainerd MN 7/2024
Old 03-08-2018, 09:37 PM
Half-Inch Stud's Avatar
600 hp is right. Is that still 300 cfm heads?
...got a 2-bolt block (drilled for 2-bolt) that has been mid-9" in a door car. Looks fine.
Old 03-08-2018, 10:40 PM
BADDTA's Avatar
BADDTA BADDTA is offline
309 cfm gave us 612 hp in a 434 10.75:1 solid flat tappet motor
Brian
Boobs & bacon
Old 03-08-2018, 11:18 PM
Was going to start with 461ci. Looks like I'll need heads, currently 670s that flow 230cfm, guess they won't cut it
Old 03-09-2018, 07:26 AM
steve25 steve25 is offline
The 670s will cut it if they get ported to 275 cfm and chambers get machined out to later open style!
Old 03-09-2018, 01:13 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
I went 9.99 10.00 in 1995 3000 lb car 455 ra4 heads and a hyd flat tappet cam no need for expensive valve train to run numbers u want to
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 03-09-2018, 01:58 PM
ponyakr's Avatar
ponyakr ponyakr is offline
http://www.wallaceracing.com/hpcalculatorquarter.php
Old 03-09-2018, 04:20 PM
Old Goat Racer's Avatar
Are you guys talking 600 HP at the flywheel?
Everybody knows somthin.
Nobody knows everything !
Old 03-09-2018, 09:32 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Do you need to run 10 flat in all weather conditions?
May need more power for july / august.
Old 03-10-2018, 04:12 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
600 at the tires.
Old 03-10-2018, 09:39 PM
Less than 600 at the flywheel COULD get you 10 flats... POSSIBLY less than 570 hp... However it would be best to build to 600 + hp and dial back if need be.
Old 03-11-2018, 12:04 AM
Dragncar Dragncar is offline
2 bolt factory blocks with studs are good to 600-650HP. Not really worth it to do the billet cap thing anymore.
SD Performance has a 265+ cfm CNC program for 670s. Its around 1600$ for a complete pair of heads ( your cores) setup for Solid roller. I had a set of 48s done and they went 272cfm.
600HP is not hard with those heads.
The guy I sold them to (never run) has them for sale for less than I got for them. 2,000$. Worth every penny. Cores are worth 400$. They have full bronze guides, hardened seats, Ti retainers, filled crossovers. 69-70ccs. Great heads, wish I did not sell them.
Old 03-11-2018, 09:41 AM
According to Wallace, my 3100 # car with driver that went 10.05 has 543 HP at the rear tires and 603 HP at the flywheel.
